E-Class (W211) 2003-2009
OEM Cross Drilled Sport Rotors on Standard Model
Old Feb 3, 2010 | 01:16 PM
timannnn's Avatar
2014 E350
Looking to replace my stock solid rotors for stock (sport model oem) cross drilled rotors in the front. Has anyone accomplished this task? I have the part numbers thanks to konigstiger but am not sure if the rotors will fit or not as the cross drilled are supposed to be a thicker rotor. 2006 e350 elegance model.
Any help?
Old Feb 3, 2010 | 07:46 PM
pinebaron's Avatar
07 E320 Bluetec
Curious
Any help?
Any particular reason you are going for cross drilled rotors ?
Old Feb 4, 2010 | 12:19 PM
timannnn's Avatar
2014 E350
I would like to keep oem quality but enhance the look. I have a set of aftermarket wheels that show off the rotors.
Old Feb 4, 2010 | 06:30 PM
pinebaron's Avatar
07 E320 Bluetec
Review this link before you decide; I just picked one of several on the net.
http://buildafastercar.com/tech/Drilled-Brake-Rotors
Old Feb 6, 2010 | 02:09 AM
Benzzin's Avatar
'03 E320
I'm a baller on a budget so I painted the calipers red and got my crossed drilled rotors off ebay! I was going for the aesthetic look also. So here are a few pics!
Old Feb 6, 2010 | 01:03 PM
timannnn's Avatar
2014 E350
I don't really trust rotors bought off of ebay. I was going to buy cross drilled rotors from the dealership for the sport model. That way I know they are oem quality. I think the horror stories of most cross drilled rotors are from using them at the track where the rotors are undersized and extremely over driven. Also thinking zimmerman but don't know much about them.
Old Feb 6, 2010 | 04:36 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
i'd stick with OE on the rotors as well. the 500 rotors are drilled but idk if you need the bigger caliper since those come with a 4 piston caliper up front.
EDIT: our CL500 has crossed drilled rotors. also the 350/550 sport models had cross drilled as well. you should see if any of those can fit. i'm pretty sure it would be fine, the size difference isn't that big. i mean, e55 rotors wouldn't work, those are just huge.
Old Feb 6, 2010 | 04:43 PM
timannnn's Avatar
2014 E350
Thanks gaazmon. I definitely want to stick with oe rotors but no one seems to know if the sport rotors will fit. I think what I will do is just measure the diameter and thickness of the stock rotor on my car and then go to the dealership and ask to see the sport rotors and go from there.
Old Feb 6, 2010 | 07:26 PM
TheGreatOne45's Avatar
2018 GLC 300 4Matic
will they fit on a 4matic?
Old Feb 6, 2010 | 07:49 PM
gaazmon's Avatar
i remember seeing an 08 e350 with amg sport package at the building next door of my work building. it didn't have the fancy "brembo" style calipers that say Mercedes Benz on them that the E350/550 RWD do, but it DID have cross drilled rotors. i thought it was odd that i didn't have the nice calipers, but THEN noticed it was 4matic. i also remember seeing someones e550 4matic here and that also had drilled rotors.
