Driving my Eclass in the snow
Are you running CLS's staggered wheels ? There are posts here that explain how staggered setup can damage the 4Matic drivetrain .. bottom line is they say the overall diameter of all 4 wheels should be the same
I'm craving staggered wheels but this is whats holding me back...
Did that twice but dont make it a habit, i try to leave a distance infront of me before red lights and inclines so i dont have to stop. I had lots of practice driving in the snow in my youth on a 69 Malibu with bias py tires, talk about 360s. I did learn going up my drive way, if you start to lose traction, turn the esp off, with it on you can floor it and not much power at all
I've gotten stuck once this winter, a parking spot uphill which wasn't plowed for a while. Had to get people to push me off.
I'm lowered, 265 in front and 285 in the back. Went up big bear, had to use cables on the back tires I had raised it up with the airmatic. Not a lot of fun, met my dad up there in his Honda and we drove in it for the remainder of the stay. Went up and down a fair amount of steep hills. Front end pushed a lot and I thought I'd be into the side of the mountain or off the cliff a couple times. At that point I decided it'd be wiser to slow down a little.
There were a couple of inclines, where there was not going to be any way I could go up without the traction control off.
Yes, this socal guy is a wussie.
The cables would not let me get up past 40-45 mph after I put them on, as they started touching the inner fenderwell
And no they are not winter, or all season tires.
the sand that was put on the roads sure beat up the paint though
ummm a little bit, the handling got a little better in the snow, but i also i had to get the tires changed. Running the staggered will mess up the 4matic system from what ive heard, and we get a good bit of snow up in here in pittsburgh, so i didnt wnna mess with that, plus it didnt even really look an different.
Man, I had an absolute blast driving my 06 E55 in the snow!!! I tried to make my car fishtail (within reason) and couldn't do it with the ESP. Turn that off, and it's a different story... I felt pretty confident with my cruise control set at 60 (it is 55MPH zone) and had absolutely no problems. I was passing many other vehicles with no problems. Not once did I feel that I was in danger of losing control... This is with ultra-high performance tires that are over a year old on the front and about 6 months old on the back (needless to say, that on this car, both sets are due to be replaced). The road is pretty curvy and has a lot of hills as well... I have driven many front-wheel drive vehicles in the snow and I would say that this vehicle outhandled any of them!
I guess it is all a matter of what you are used to driving in. I used to drive an S-10 around in the winter with no weight in the back in an open field in the snow just so I could learn how to correct a slide... One thing you have to learn is NOT to hit the brakes when you feel your vehicle sliding... You need to take your foot off the accelerator just a tad (but not too much, as this can make your vehicle slide just like hitting the brakes) and turn your steering wheel slowly wherever you intended to go (basically turning into the slide [e.g., if your rear ending is sliding out toward your right as you are sliding, you turn the steering wheel to the right]. This is something that takes practice, as your instinct is to slam on the brakes and turn your steering wheel in the direction the front of your car is going (instead of the direction that the rear of vehicle is going). You also need to learn the "feel" of your car during different situations (including the feel of the steering wheel). I can feel when my vehicle is about to hydroplane or slide before it actually does...
your sarcasm cracks me out haha
Has anyone tried high-end tire chains on their W211? How did they fare?
It seems in the D.C. area, no one knows what a tire chain is. Fortunately I got my older 300E running recently. With about 200 pounds of sandbags in the trunk and chains on the rear tires it does rather well in snow.
My wife's ML (she tows a horse trailer, so she gets the SUV), seems to do ok, but I think it would do a lot better with real snow tires. The all-seasons are fine, but it's not the same. I haven't been able to convince her that a spare set of wheels with snow tires might actually be a good idea.
