E-Class (W211) 2003-2009
fly in the ointment...errr headlamp assembly
Old Feb 20, 2010 | 03:01 PM
gaiser's Avatar
C280, ML350, E500 4Matic
I have no idea how this little guy got trapped; however, does anyone have any suggestions on how to get him out?
I was thinking of using Scotch double sided tape wrapped around a straw or pipe-cleaner; then, using my makeshift tool, fishing him out via the turn signal bulb socket.
This is where I ran into my first issue. How do I remove the turn signal bulb without removing the entire lamp? If I have to remove the lamp, is there a way to do this without removing the bumper cover?
Old Feb 20, 2010 | 03:25 PM
tbone's Avatar
E500 Sport
LOL
Old Feb 22, 2010 | 08:27 AM
infantry's Avatar
07 E63. 07 STi limited #606/800
sorry i dunno how to help you but.... LOL this is prob the funniest pic ive seen...
Old Feb 22, 2010 | 08:35 AM
wampa's Avatar
E500 & ML500
Originally Posted by tbone
LOL
x2
Old Feb 22, 2010 | 08:39 AM
vettdvr's Avatar
03 E500 and Corvette
Compressed air and small nozzle????
Old Feb 22, 2010 | 12:34 PM
timannnn's Avatar
2014 E350
the only way to really get him out is to remove the headlamp, put the headlight in an oven (150 degrees for about 5 min) and then pull the clear plastic lens and separate from the headlamp. But to remove the headlamp you need to pull the front bumper. Not sure if it's worth it to you. But if you are removing the headlamp you could always throw in some bi-xenons in there.
Old Feb 22, 2010 | 12:46 PM
werewolf34's Avatar
2009 E350 Sport
I believe you catch more flies with honey...so less honey
or...
You could put a spider in the light to take care of the fly but then you'll have a spider problem...
Old Feb 22, 2010 | 12:56 PM
saintvir's Avatar
'23 EQE 350 4MATIC
One time, I had a bee trapped inside the headlamp assembly. My car was still under warranty at that time so I took it to the dealer. They managed to get the (dead) bee out ... no problem. How? I don't know exactly. My SA said something about vacuuming it out.
Old Feb 23, 2010 | 08:59 AM
adisco93's Avatar
2007 E350 4matic- winter edition
LOL! Funny enough, the day I went in to purchase my 07 E350 there was a dead bee in my tail lights as well. Saw it as I was doing my visual inspection! The dealership had it removed before i took delivery- not sure how this was achieved either. Arent these things supposed to be airtight?
Old Feb 24, 2010 | 03:45 AM
aintez's Avatar
E500 2002. Supra TT 97, Supra NA-T 94, Glanza 96, Starlet 90
or...
What a funi guy !!
I am about to do this to my rears, got a bug in there.
Best and easiest i would think is vettdvr's suggestion, just go to a garage they should be able to help you and shouldnt charge more than 5-10bucks. ust their time to take your bulb out and then blow away
Old Feb 24, 2010 | 10:02 AM
Frasmat's Avatar
W212 E350 P2 AMG Appearance
Your dust cap was probably loose and the fly was flying around your engine bay caught a glimpse of light, and went for it.
Old Feb 27, 2010 | 06:52 PM
gaiser's Avatar
Managed to get it out!
The factory workers in Graz that assembled this car must have small hands! I managed to contort my arm behind the headlamp, remove the turn signal bulb, and using a flexible drinking straw wrapped in double sided tape, fish the fly out of the assembly. A vacuum would have been easier, but I did not have a nozzle small enough to fit behind the lamp.
Old Feb 27, 2010 | 07:17 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
i had a fly stuck in my right tail light. idk if it's still there.
Old Jan 29, 2012 | 05:34 PM
ozusa's Avatar
2004 E320 4matic Sedan
How to remove an insect from the front headlight turn indicator
Yes, it can happen.
I had a (dead) yellow jacket in the top part of the headlight assembly where the orange turn signal lamp is. A yellow jacket is a wasp, for those of you who are not in USA.
Materials: about 3 feet of 1/4 inch clear plastic flexible tubing.
1) Check that your turn signal works so you are not left wondering if you damaged it doing this procedure
2) Remove the orange lamp bulb by turning counter-clockwise about 30 degrees and pulling backwards. The lamp is fairly easy to access, on the right hand side, anyway. There are no wires/leads on the lamp insert to worry about. The current is supplied by contacts on the lamp insert. Therefore nothing to plug or unplug.
3) Insert the tubing carefully in the hole where the lamp was and get it past the "lens/reflector" that is in front of where the bulb goes in. This may be a little fragile, so don't snap it off by just jamming the tubing in carelessly.
4) Manipulate the tubing close to the insect/debris
5) Use lung power to blow the insect toward a corner, if needed
6) Exhale as much as you can, but not into the tube this time. You are going to need empty lungs to make a vacuum.
7) Suck the insect into the end of the tube. Maintain vacuum while you draw the tube, with insect, out of the lamp assembly
8) Re-assemble bulb into assembly
9) Check signal still works
10) Don't tell anyone what you did. They'll laugh at you. Under no circumstances post instructions on the net if you want to maintain any kind of credibility.
Old Jan 31, 2012 | 11:44 AM
XLR82XS's Avatar
2006 E500 4matic wagon
F it. Just upgrade to 07+ headlamps. ;-)
