air suspension?
air suspension?
Came out side this morning and the back end of my car was almost sitting on the wheels i thought maybe the air suspension went because the front of my car was looking normal. I then started car and push the raise car button and it took a min but everything raised. So i thought the car was fine. Push the raise button again so it would be normal, I drove then parked it again and same thing happen this time more on the passenger rear side. Its not right away it take about an hour to do this. Any ideas is the is the air shock shot or is this normal. I live in new jersey so got alot of rain but wasn't near any flooded streets.
Sounds like at least one of the air shock or air springs (in the rear) is failing. Or maybe it's the air pump. You should get it checked out at the dealer or a very good MB indy shop. It's an expensive repair. Probably looking at $1200-$1500 per corner, parts & labor. One of my front air suspensions failed at 60k mi, and the dealer quoted me ~$1500 for the repair and I ended up paying $1200 after a $300 good-will discount.
went to my mechanic and he saw nothing wrong he then put the computer on and he said there was a fault code "c14fc" in electronic stability control. He said there was no description and he would have to look it up and call me tomorrow. Does anybody know what it means. Thanks
The leak will develop in a fold in the rubber specifically on the rear air spring. Hopefully it is an air shock and not the spring. The spring requires (really dumb) pulling the rear differential/suspension out of the car to change the spring.
What you really need is a "leak down" test done on the car. Mine was taken to the dealer twice before they found the leak. When they found it the air springs AND air compressor had to be changed out. Read $$$$$$$$$$$$$$$
last thurs i go the visit workshop car icon. Could hear the compressor coming on and on constantly. Called the dealer on friday and said to bring in asap or get it towed if can't drive.
I didn't drive it on the weekend but took it in on monday. Picked up the car tuesday and the invoice said no voltage to airmatic release valve, bad red/black wire, installed new cable/wire harness. test drove and code cleared by tech.
Granted its still under CPO thru 2013 and/or 100k miles...
