Electronic Trunk Closer - Open and Close Speed
On mine, when it opens, it seems like a manual open where the latch releases and the trunk lid springs open to its max height.
On closing, I sear it will take my head/arm off if I am not fast enough.
Is this behavior normal?
On closing its not ridiculously fast, but I don't push the button and wait around .. it does about 10 degrees at a normal speed and then it picks up the speed to close properly .. its definitely what I would describe as "power close"
The E uses an electronic motor---much quicker---
If the trunk is slamming shut (rapidly) you have an issue. As previously mentioned, may be an issue with control unit. Really is an issue than should be remedied, continued use can cause damage to trunk arm and/or actuator requiring replacement ($$labor$$)....
Aaron
I did that too b/c they never tried to work with me or even messed up stuff that was perfectly fine just to sell me more stuff and I found a dealership which works WITH me not AGAINST me.
A2118703026
You need to replace your current trunk module to the following revised part to restore the original factory trunk closing speed:
2118703026
Hope this helps!
(Left: OLD; Right: NEW)
I also want to add, that if you don't fix the fast opening and slamming of the trunk, it will eventually break the mounting bracket on the trunk hinge that the trunk motor arm attaches to. My bracket was pretty much busted so i went ahead and installed a new trunk hinge to prevent further issues later. Which was an absolute ***** to do. Someone must know what the easy way is to remove the rear shelf trim?
Well, hopefully this helps someone else at some point.
Aaron
Send me your email address and ill send you WIS document that shows how I remove the hut shelf! It's a ***** that just up front. Especially if someone broke the latches that release the rear head rests!!! Took me 6 hours to just get them off bc a mechanic broke off all three release latches on my car a few years ago (and of course never bothered to tell me that they broke something)!!!
