Can you add Bluetooth to an '07 E350 that's not pre-wired for it?
One dealer said it has to be factory installed for '07 and another dealer said you can buy the parts to install it for around $1025 (wholesale). Has anyone had this done on an '07 that didn't come pre-wired for Bluetooth?
It is $900 from here:
http://cartronics.com/MBMost.html?MBClass=E&VIM=1
I just had the satellite receiver installed. It does work as advertised. They are a little pricey, but they work like the factory unit.
Good luck!
Mike T.
Good luck!
Mike T.
2005 E500, 2011 ML350
You should just have to buy the control unit, connector for cradle, and the cradle itself....install is 2-3 hours. You may also need SCN coding for the option to display on cluster.
No the car is not pre-wired. No connector in the center console storage box. The Cartronics system looks like the only option.
The base for the cradle is only there is phone system is pre-installed (389). I have yet to see an MY07 211 without prewire for phonesystem. You would have to remove the panel and there would be 2 plugs for the cradle base to plug into. If you look at panel it should also have a silloute that you pop out for cradle base to snap into.
The quality of aftermarket bluetooth system is poor compared to OEM......
Go to this site or call them to find out if all you need is the module: http://www.wireless4mb.com/
If you have a 2007, I thought all you needed was the Bluetooth module, which you slide into the console in a couple of minutes, using no tools. The module is around $500 from the dealer, or about half that on Ebay.
I think that came with P1
On a datasheet, would option 387 be present if option 389 is? I ran a VIN for a car I'm looking at, and it only includes option 389, no option 387. Does this mean I can just buy the puck and simply connect it for a 60 second install?
K7 GSX-R 750
If it is NOT pre-wired with access in the standard arm rest area. Then I believe OP would have to go through Cartronics...
