E-Class (W211) 2003-2009
Help -- just bot 07 E350 4matic - gap in front hood/bumper
Old May 16, 2010 | 02:16 PM
nasdaqer55's Avatar
2007 E350 4Matic
Just bought an 07 E350 Sport 4Matic, but noticed something in the front. The one owner carfax said it had never been in an accident, but.... take a look at the photos -- is there some way to adjust this? I did buy it from a dealer....
the driver's side is fine, but as you can see I can fit my whole hand in the gap on other side....
Attached Thumbnails Help -- just bot 07 E350 4matic - gap in front hood/bumper-dsc06108.jpg   Help -- just bot 07 E350 4matic - gap in front hood/bumper-dsc06107.jpg
Old May 16, 2010 | 02:25 PM
nasdaqer55's Avatar
2007 E350 4Matic
gap
FYI, the hood seems straight, as does the passenger quater panel, as well as the front molding, but its just not fitting tightly. Is this an easy adjustment I am just missing?
Old May 16, 2010 | 03:53 PM
nasdaqer55's Avatar
2007 E350 4Matic
Am I screwed? or is this an easy fix
Old May 16, 2010 | 08:56 PM
nasdaqer55's Avatar
2007 E350 4Matic
Anyone?
Old May 16, 2010 | 10:21 PM
starbrite's Avatar
2004 E320
Those pics are so dark they don't show anything !
Old May 17, 2010 | 11:08 AM
MB211's Avatar
2005 E500, 2011 ML350
Is the hood fully shut? Try openning and closing a little harder....looks like left side is latched and right is not......
Old May 17, 2010 | 12:03 PM
nasdaqer55's Avatar
2007 E350 4Matic
shutting hood
already tried, but to no avail. is there a way to adjust the hood? everything seems straight - all the gaps on the body panels and hood seem the same....
Old May 17, 2010 | 12:09 PM
nasdaqer55's Avatar
2007 E350 4Matic
hood
here's a picture of the car,, if you look closely, you can see the gap between the hood and the fender
Attached Thumbnails Help -- just bot 07 E350 4matic - gap in front hood/bumper-merc.jpg
Old May 17, 2010 | 03:33 PM
nasdaqer55's Avatar
2007 E350 4Matic
going to the dealership tonight... I bot it used, but the place I got it from has a 3 day money back guarantee,, told them i would retrun it if its not repaired/fixed for free.... hope they don't call my bluff
Old May 17, 2010 | 03:36 PM
lorryfan's Avatar
2019 S560, 2008 E350 4MATIC
I still can't see it from the direction the picture was taken. Can you take additional pictures?
Old May 17, 2010 | 03:49 PM
nasdaqer55's Avatar
2007 E350 4Matic
will do. look at the first post, i can fit my hand in between the headlight and hood
Old May 17, 2010 | 03:54 PM
nasdaqer55's Avatar
2007 E350 4Matic
first picture is what it should look like,, from the driver's side. second picture is what the passenger's side looks like
Old May 17, 2010 | 05:01 PM
konigstiger's Avatar
'71 Pinto
Private mail your email address, I will send adjustment instruction sheet including correct gap dimensions to fender, headlamp, and grille. Include VIN if you want a MB datacard showing initial delivery date, factory-installed equipment/codes, etc.
Old May 17, 2010 | 11:32 PM
nasdaqer55's Avatar
2007 E350 4Matic
Dealer just called -- they are ordering a new headlight and assembly unit. "very expensive for us, but good for you.." there was a clip broken on the headlight assembly that probably caused the headlight to go out, as well as being out of whack.
Old May 18, 2010 | 03:23 PM
crazypotato's Avatar
E320 CDI
Do you have rear bumper adjustment instructions for W211 CDI E320? 211.026. The bumper is popping out a little bit on both side. If it is a WIS document, can you send the document no.? I have WIS too.
Old May 18, 2010 | 04:12 PM
SPNJHockey's Avatar
07 E350 4Matic / Sport with P1
Nice, Bro. Doesn't cost anything to ask, does it?!!!
Old May 18, 2010 | 04:58 PM
'71 Pinto
AR88.20-P-2200T - check that guides (17) are seated properly on brackets (18).
Old Sep 17, 2011 | 01:32 AM
whytechno's Avatar
2010 E350
Old Dec 1, 2014 | 12:34 AM
E55w211's Avatar
2005 e55 AMG
Cool
Nasdaqer, I have the same issue, could you please give me specific details on how was the gap problem solved.
Attached Thumbnails Help -- just bot 07 E350 4matic - gap in front hood/bumper-image.jpg
Old Dec 1, 2014 | 12:49 AM
E55w211's Avatar
2005 e55 AMG
Cool
It's as bad I guess.
Old Dec 1, 2014 | 01:09 AM
E55w211's Avatar
2005 e55 AMG
I got the car a week ago from a dealer in Houston and I am shipping it to my country inside a container and I'll get it next week. It's a one owner clean car fax and really clean car. I am a Beemer guy but this one is making me fall in love all over again.
This is it being put inside the container
Old Dec 1, 2014 | 01:14 AM
E55w211's Avatar
2005 e55 AMG
Old Dec 1, 2014 | 01:20 AM
E55w211's Avatar
2005 e55 AMG
Headlights seem tight and in order, should I lossen all screws and try to align it? Is it that simple?
Old Dec 1, 2014 | 11:50 AM
E55w211's Avatar
2005 e55 AMG
Anyone?
Attached Thumbnails Help -- just bot 07 E350 4matic - gap in front hood/bumper-img_20141120_151536.jpg
Old Dec 1, 2014 | 12:43 PM
'71 Pinto
Check lines 25-27 here http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
