Would you buy this car after seeing this CARFAX? help/option?
Please help. i confuse about this one. what is you option.
iam looking at this e350 to buy, but unsure about its history.
The price on the sticker now is $25,997. IS IT WORTH IT?
My first concern is that it was a lease car/fleet. Could this been a rental car? or just a lease compnay car.
what is you option on company cars? Do you think it was abused?
It looks like the car did alot of miles in years it was on the road. seems like highway miles. maybe?
Also i calulated the miles betwween service.
The first service after 4850 was at 13,305.
which is 8455 miles done for the first oil change which is right under mercedes 10,000 oil change mark. which i thick is good.
After 13,305, the next service was at 26,420,
which is 13115 miles done and over its 10,000 mile. and it had a Camshaft position sensor replaced.
what is a Camshaft position sensor? why would that be changed?
kinda bad right?
Would you buy this car if it was you?
What do thick about the milage and the services it had done?
Do you thick the car is in good shape and not abuse?
Should i be worryed if i buy it?
It was probably changed because it went bad... it happens. Not necessarily a bad thing. Without it, the engine won't run (properly).
As far as going 3,000 miles over the scheduled service interval... can't tell you. Depends on whether the engine is burning more oil than usual (be careful of claims that say an engine doesn't burn ANY oil. By design, a good engine will always burn a little bit of oil. If it doesn't, it was built too "tight" and that's bad), or if most of those miles were spent on the highway. If they were highway miles and the oil level wasn't too low, I would venture to say the motor is fine.
If you can wait for a week or so, get an oil sample from the engine and send it to a lab for testing. I recommend Blackstone Labs ( http://www.blackstone-labs.com/ ). The price for a UOA (Used Oil Analysis) is more than reasonable. You'll pay around 25 bucks for a one off sample. But they will tell you how the engine is wearing. I send off samples for all of our vehicles every other oil change. A couple of years ago, one report came back with copper issues. They warned me of a possible engine failure. About 15K miles later, a crank bearing went south.
I can't comment on the rest of it because I can't look up the carfax....
how much of the oil do i need for a sample?
thanks
A couple of ounces is all you'll need. I believe the containers Blackstone sends me are 4oz containers.
You don't have to wait for them to send you one of their containers, you can send them the oil in a clean plastic container yourself.
how did your E550 hold up? how much miles did it have when you got rid of it? how did you like that on gas in the city?
thanks for the info
My E held up well. It had a few typical MB minor issues. Check suspension/engine lights were fixed with some flash/sensors. Sunroof sensor replaced, drivers door handle replaced for keyless go issues. It may sound like a lot, but they were minor and all involved two visits. I though the 211 E550 was a near perfect car, I like it significantly better than my 212. I hated the 212 so much I was out of it in 3 months. I had roughly 36k on it. I have seen the leasing/rental on many carfaxs. There are several reasons, corporate ownership, rental (not likely if it has higher miles, they sell their cars before 20k), etc. I do not know if it means MB leasing.
I will tell you, whatever you do, get a 550 if you can, it is a BEAST...
how many gallons does the 550 hold full and how many miles on a full tank?
and do you do alot of city or highway miles?
1- Car Dies
2- CEL on
3- Car starts after 10 minutes
4- CEL off after a few hours of the car being shut off
5- After a few days, go back to # 1. It starts happening more often as time goes by.
It is a $40 fix and a beatch to get to, but easily done for a DIY'er
Cheers
Take the VIN number and call your dealership and have him run a VMI to double-check the history and possible problems
If you look somewhere on the car (usually the windshield) the Data Scan inspection and reference number will be on their sticker. Otherwise you can try using the VIN.
Data Scan has the check list report plus pictures (they take detailed digital photos) of the car at turn-in time.
I know how I drive whenever I get into a rental whether it be when going on vacation or getting one from MB service...
And I'm pretty sure I'm not the only one going bonkers on these rentals either...
I have leased 2 cars as well and I kept both in immaculate condition. Just went ape **** before the lease turn in.
