E-Class (W211) 2003-2009
AC blower comes and goes
Old Jun 3, 2010 | 01:50 PM
merandad's Avatar
It is hot in Dallas and the Ac unit in my 2003 E500 started a new game. The Blower stops blowing air out but showing the fan speed/bar disply to be working. I have turned the system off and back to on and it works. The air is cold as it should be. A few weeks ago, I had a chirping noise from the blower and I took it out to lubricate the moving parts. Now the chirping is gone but blower stops and go. Please share your thoughts as if I need to replace the blower fan or the regulator or both? Thanks in advance.
Old Jun 3, 2010 | 04:22 PM
Barry45RPM's Avatar
2015 ML 350
You need a blower fan regulator (module) it installs under the dash passenger side. You kan keep the blower running in the mean time if you manually keep it from entering the MAX blower speed. (No AUTO). When it enters MAX (fan speed as in DEF or MAX settings) the unit quits blowing sometimes.
Turning off the car for a long while will reset it but its a known problem in your car. (Had it in my '04 way back when when no one had heard of it... but there is a fix)
Old Jun 4, 2010 | 01:19 PM
merandad's Avatar
Thanks.I'll order one and try to replace it myself. I think it should be close to the blower fan.
Old Jun 4, 2010 | 04:32 PM
konigstiger's Avatar
'71 Pinto
Current part # is 2308216451 (for comparison shopping, autohausaz.com http://www.autohausaz.com/search/mod...00016&year=All $162.93)
https://mbworld.org/forums/3888972-post13.html
Old Jun 4, 2010 | 10:23 PM
merandad's Avatar
Great pix, very helpfull. I am sure with the helpfull pix and a few Aleves I can do it. Thanks again. I'll report back.
Old Jun 4, 2010 | 10:40 PM
mikekuriger's Avatar
2010 C63
interesting, my C55 does that also sometimes. I have stopped using the AUTO mode which seems to cure it. I leave the fan on 2 or 3 and it's fine. I wonder if this module is bad on my car?
Old Jun 5, 2010 | 08:29 AM
vettdvr's Avatar
03 E500 and Corvette
If the blower fan is chirping and you had to lube it I would replace it also.
Old Jun 6, 2010 | 01:48 AM
merandad's Avatar
It is logical to replace them both, I agree. I started looking at few online MBZ part stors today and they all offer a a same brand OE with different part #s. is there a difference between parts? The prices are almost the same.
Old Jun 6, 2010 | 06:41 PM
'71 Pinto
2308210251 installed at production, replaced by 2308216351, replaced again to current 2308216451 - replacement usually indicates modification.
Old Jun 14, 2010 | 12:34 PM
merandad's Avatar
Bought the OE parts and took a few Advil's and replaced the blower and the regulator. the blower was good but replaced it anyway. I am happy now, it works great. Thanks to all good comments.
Old Jul 4, 2013 | 06:50 PM
mister mers's Avatar
96 w210, 03 e500
regulator 2308216451 for $59.99
Just found it online. Will post later how replacing went.
Old Jul 4, 2013 | 06:51 PM
96 w210, 03 e500
Now this regulator sells much cheaper, for $59.99 No modifications required, very easy to replace.
http://www.ebay.com/itm/171069925631?item=171069925631&viewitem=&vxp=mtr.
