How to skip through preset radio channels on steering wheel?
Ok, We know now that some later build 2003 E's are set up to scroll through the PRESETS from the stearing sheel.
The question now is, has anyone had luck yet in getting an upgrade to software installed bye the dealor to fix this problem in the first bulit 03 E's so THEY can scroll the presets instead of the Freqs.?
)I just went out to my car, turned on the ignition, pressed the steering wheel page button to the audio section, had the FM station playing, and then hit the up and down arrows.
Results?..... it scrolled through my "preset" stations, i.e., NOT freq's.
Mark
It also has the same speaker glitch in the Logig 7 mode that I reported in another thred.
STKLAW - I'm am in no way questioning your ability to scroll - I am totally jealous if you have this function! Just tossing out an idea.
Bruce McDonnell
well, his dealer in partly full of crap.... i.e., my E500 bulid Jan 03 does scroll through preset stations.
Mark
the scroll preset should just be an option..or just come standard on the cars
maybe BMcd'd theory is right
My car is April build and I have the problem too. I take it to the garage today, and my dealer says me first it is an option and I have to change settings. I tell him to show me and he doesn't find the "option" but he promised me to fix it by software upgrade. The car is there until tomorrow, I'll see.
LOL...the dealor was trying to find that option....he will be looking for a very long time.
Please let us know kevinR if in fact your dealor makes good on his promiss to fix this through a software upgade....we are all waiting for the same thing.
Mark
My guess is that the person who thinks the wheel scroll does work used the auto preset tuning function and lives in an area with limited radio stations. THis would set all of the presets in order from lowest to highest frequency. When he "scrolls" he's actually seeking the next strong station but since it is in memory from the auto-tune, it looks like its scrolling presets.
Just a theory.
So, this confirms I'm scrolling "Presets". Mark
I did consider Bundy's suggestion and I went and tested again. Yes, my area has lot's of stations. But when I scroll through the presets, it's making jumps like 94.1, 99.9, 104.1, 107.3 etc. There are stations inbetween my presets. To top it off, each preset is also displayed with the assigned preset number, e.g., 94.1 is my first station and would have "FM1" displayed...... 107.3 has "FM8" displayed, etc.
It is obvious that an error was made on your car as most of the rest of us don't have that feature. I think you should turn yourself in to a MB Dealer and have then screw yours up like the rest of us....
Ed
edit: I assume that everyone is talking about the HK system and not some with the basic and some with the HK????
Would you be willing to try one more test which involves resetting all of you presets?
After the test you would have to reset all of your presets to your current preset stations.
If you would like to take the time to try, then I will post a step by step test I would like for you to try. ??????
mkassab
Mark
Regarding "the test"
1. using SEEK - find the lowest FM Freq either audio or static (87.7 on my tuner) then enter that into the #1 PRESET, as you know you will hear the tone when the preset "takes" and FM1 will be displayed in the lower left corner of the dispaly.
2. Using SEEK+ advance to the very next audio station, ONE PUSH, enter into #2 PRESET.
3. Repeat the above steps until you have all 10 in the presets.
Its very important to ONLY SEEK to the next Freq. after you have put the previous one in its PRESET. (One Push of SEEK +)
4. After all 10 stations are in the PRESETs, go to the steering wheel and try scrollng.
5. This is the Main objective...When your scrolling on the steering wheel, watch the presets numbers, FM1,FM2 ect, on the lower left corner of the display. When you get to FM0, press the same arrow on the wheel that your using and push it ONE MORE TIME.
What shows up on the display....FM1 or is it BLANK AND you are recieving another radio station?
Mike
as i said it isnt able to be done. those arent presets , they are the strongest stations.
