E-Class (W211) 2003-2009
AZN Optics 194 5W5 LEDs for your w211 City lights
Rating: Thread Rating: 2 votes, 5.00 average.
Old 12-28-2011, 05:34 PM
  #301
kyastas's Avatar
W212 E63S
Just placed an order for day-lights and license plate bulbs for 06 E55. Can't wait to get it
Old 12-30-2011, 07:01 PM
  #302
kyastas's Avatar
W212 E63S
Got my LED's Installed for license plate. Perfect, very happy Did the front lights not so much luck LED's goes on for split of a second goes off and after a second goes on again and off( included video).
Does anybody has any idea what is going on, or just simply my doest like it
http://www.youtube.com/watch?v=iyh0FPXVKak
Old 12-31-2011, 01:34 AM
  #303
SPONSOR/MBworld Guru
AZN Optics's Avatar
Looks like it's just the passenger side with the driver side working fine? Try swapping left and right side and see if the issue follows the LED (if so, probably just a faulty LED and we can warranty that), but if the issue stays with the socket, you could have a socket issue. Try cleaning out the socket to make sure it's free of corrosion and make sure when you pulled it out, you didn't pull out any of the wiring into the connector by accident.
Old 12-31-2011, 03:20 PM
  #304
kyastas's Avatar
W212 E63S
The thing is regular bulbs works fine. Led's left and right just blinking.
Old 12-31-2011, 11:19 PM
  #305
AZN Optics's Avatar
ok, no worries. might just be defective or damaged during shipping. Send an email to aznoptics@gmail.com and include your username, name, address, and the bulb type and color and we'll get a warranty bulb shipped out to you.
Old 01-03-2012, 08:08 PM
  #306
kyastas's Avatar
W212 E63S
Just now forwarded google check out invoice to you. Thanks.
Old 01-05-2012, 06:23 PM
  #307
Sebfto's Avatar
E240
my number plate festoons went after just 2 months on the car and one of the front city light led's also gone . one still holding there but from time to time I get an error on the dash from that .
Any idea what can be the cause of that ?
regards
Old 01-05-2012, 06:26 PM
  #308
AZN Optics's Avatar
regards
Hmm, take a picture of both sides of the LEDs and email to me at aznoptics@gmail.com so I can assess them.
Old 01-06-2012, 01:50 PM
  #309
Sebfto's Avatar
E240
Just sent an email !
Old 01-06-2012, 01:52 PM
  #310
AZN Optics's Avatar
Yeah, you've got my previous gen festoons. I've since redesigned them with built in heat sinks to help protect them from surges and dirty voltage. I'll shoot out a warranty replacement.
Old 01-06-2012, 01:54 PM
  #311
Sebfto's Avatar
E240
that sounds lovely ! have you still got my details ?
how can I get the other front one? paypal?
Old 01-09-2012, 01:06 AM
  #312
AZN Optics's Avatar
Ok, just met with my w211 tester. Apparently my last batch has of 194 Wedge in 5000K has an issue with w211s with them blinking on and off. We tested my 8000K from previous batch and they worked just fine. So for those of you with this blinking issue, you have two options at this point....One, I can issue a full refund and will comp you for return shipping of the LEDs, just shoot me a PM letting me know what you want.... or Two, I will put your contact information down for my next batch which should be coming in mid-end of this month and ship you a new set that should be back to my original spec and design before this issue popped up. All I need from you is a PM with your name and address and transaction number and I will mark you down.
I apologize for this issue but was told by my Mercedes tech rep that the voltage specs are the same across all MB lines (except new model MLs), so when I test all these LEDs on my test C and SL, made the assumption they would work just fine for all other models. Apparently that's not the case and w211s might vary just enough in terms of specs to make them slightly different.
Old 01-09-2012, 04:13 AM
  #313
ap10046's Avatar
CLS500 M113
Hi Michael,
Both my license plate festoons went out as well. They were the heat sink variety.
Old 01-09-2012, 11:23 AM
  #314
AZN Optics's Avatar
Originally Posted by ap10046
Hi Michael,
Really? Both? Did they both just go out at the same time or did they degrade with one going out then the second?
Old 01-10-2012, 05:49 AM
  #315
ap10046's Avatar
CLS500 M113
One went out and then the other one..my MFD said left number/license plate light (or something) and then also after a few days said right number/license plate light
Old 01-10-2012, 11:26 AM
  #316
AZN Optics's Avatar
Ok, we can process a warranty claim on them. Sending you PM with details.
Old 01-23-2012, 09:10 PM
  #317
AZN Optics's Avatar
New batch of 194 Wedge LEDs for your front city lights and sidemarkers are in and have been tested and verified to work fine on w211s. Held and replacement orders will be shipped out promptly
Old 01-31-2012, 01:43 AM
  #318
JoeNobody's Avatar
Mercedes
Old 01-31-2012, 03:11 AM
  #319
dustblaze's Avatar
07 E350/W211
are you still expecting more H7's?
Old 01-31-2012, 11:49 AM
  #320
AZN Optics's Avatar
H7 (and all HIDs) freight shipment is still stuck in customs for the past few weeks with no movement from what I can see. Still working with customs and DOT to get them cleared.
Old 01-31-2012, 09:24 PM
  #321
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
Originally Posted by jonkean
Installed 5000K wedge LED's for city lights. The difference is huge!
right side has LED light, left side is the stock gross bulb.
I also updated the HID bulbs from Phillips 85122, to Osram 5000K (66240 CBI).
New bulbs is on the right, old phillips on the left. Driving at night is much better, as bulbs are brighter and color temp is closer to pure white.
All bulbs upgraded.
Any update on plug and play turn signal bulbs?
I want to upgrade the turn signal as well, but it seems nobody has plug and play led bulbs for the W211. AZN website says the 1156 wedge can work on Mercedes turn signals, except it needs additional resistor added to the wiring. Can the wedge be modified to change the built in resistor value? I would much rather solder or otherwise mod the wedge to be plug and play, instead of wiring up resistors to the harness.
https://mbworld.org/forums/e-class-w...d-parking.html
Check out this thread the OP and myself got the turns working. Very slight modification to get it to fit..otherwise its plug and play.
Old 01-31-2012, 09:27 PM
  #322
BagMan's Avatar
I also installed the 5000k wedge bulbs tonite and they are very crystal clear white, but they dont really match the OEM HIDs, which are more blueish.
What temp is the OEM HID bulb?
Old 01-31-2012, 10:07 PM
  #323
AZN Optics's Avatar
OEM HIDs are 4300k, however, as they age and degrade, they will shift up the kelvin scale. OEM should have no blue at all when new.
Old 01-31-2012, 10:38 PM
  #324
JoeNobody's Avatar
Mercedes
Old 01-31-2012, 10:47 PM
  #325
JoeNobody's Avatar
Mercedes
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: AZN Optics 194 5W5 LEDs for your w211 City lights
