E-Class (W211) 2003-2009
2007 E550 Caliper bolt size?
Old Aug 7, 2010 | 04:45 PM
MyFirstAMG's Avatar
2002 C32, 2007 E550 4matic
I am attempting to change my front brake pads on an '07 E550 with 4matic. I have the caliper type that must be removed from the rotor in order to get to the pads. The two bolts appear to be allen keys size 9 mm. Has anoyone come accross this? I guess I am going to the hardware store to look for a 9 mm allen key. The set I have goes in increments of 2 unfortunately.
Old Aug 10, 2010 | 10:41 AM
MyFirstAMG's Avatar
Ok, I ended up going to home depot and buying a 9mm allen key. It took a little elbow greese to actually get the caliper off of the rotor. Wtih old pad sill in caliper, I used a C-clamp to compress the piston. I take out the new pads and am ready to go. To my horror, they are the wrong size. The parts guy thought I said E350 instead of E550. Ok, took the pads back on Monday and started all over again. Everything seemed to work ok, but after putting new sensor on, I am still getting the <<Breakpad Wear>> message.
Old Aug 10, 2010 | 11:57 AM
lkchris's Avatar
'10 CL550, '12 GL550
Would have been better to get an allen driver socket. Works with a torque wrench and you can sure get more leverage on one for screw removal.
Old Aug 10, 2010 | 12:38 PM
MyFirstAMG's Avatar
I coudln't find one that size. Mabye it was because I was rushing to try to finish the brake job in a hurry. The only metric set I saw was at Autozone, but it was a 12 mm, 14 mm, and 16mm. I'll go now that I am not in a rush and ask one of the employees at Home depot and Lowes.
Any advice on my "Brakepad Wear" messsage still being on?
Old Aug 10, 2010 | 02:17 PM
revstriker's Avatar
K Car
Did you reuse the same sensor? They are pretty delicate and can break easy which would give you that warning. New ones are only like $6.
Old Aug 10, 2010 | 02:37 PM
MyFirstAMG's Avatar
No sir. I got a new one from the dealer for $14.
I would like to say that write up on the '06 E350 brake job was top notch. Very nicely done.
Old Aug 11, 2010 | 12:00 AM
revstriker's Avatar
K Car
Thanks!
Wow, $14 is like twice what you'd pay online.
Old Aug 11, 2010 | 08:36 AM
MyFirstAMG's Avatar
Thanks!
Getting something online is for people who actually plan to do things. I am so unorganized. I decided on a Friday that I would do my brakes on the next day. It was too late to order the parts on line, so I just went to MB of West Chester and purchased all the parts from them.
Old Aug 11, 2010 | 08:36 PM
MyFirstAMG's Avatar
I haven't given any thought to the rear brakes. Could I test it by connecting a new rear sensor and then see if the alarm goes off? I will search more threads to see if it is based on a closed or open circuit for it being good. If that causes the warning to go out, then I know I need to change the rear brakes as well.
Old Aug 11, 2010 | 10:15 PM
revstriker's Avatar
K Car
Worth a try.
I am like you sometimes. I decide I want something, and I have to have it now. Can't wait 5 days for it to be shipped to me.
Old Sep 21, 2010 | 11:32 PM
MyFirstAMG's Avatar
FYI, I finally got around to doing my rear brake pads. They didn't use the 9mm allen key but rather a torx bit. I forget the size. They came off much easier than the fronts. Replaced pads and sensor and the warning went away instantly.
