Tow hook on tne 4-Matic Wagon...?
Could use a hook on the E-500 Wagon.
One of my buds thought the re-sale value of the car would go way down with a hook. (As the next buyer would think I have been hauling bricks for a living or some such thing)
Is a hook doable without a factory "towing package" and if so, how much?
Thx.
Can't just bolt on a tow hook without a towing package...?
Totaly invisible so no value loss here
Can you see it?
Here it is folded away:
Here is the lever that you pull to relese the towbar:
A small light comes on and it says Towbar relesed in the speedo:
Here it has relesed from its hiding place:
And here it is in its place ready to tow:
Looks expensive however and not sure it can be retro-fitted.
The only information you need to get to the trailer is Running light,Brake light and Blinker and that cant be different from Europe and America?
Or do you have electric brakes in U.S too?
I would guess that this option cost around 2000-2500$ when you orderd your car new.
the european light connectors are different from the flat blade connector to our trailers here. I am thinking of getting the European wiring kit and then purchase a european trailer connector and re wire it to our flat blade kind.
Good luck with your little project
The factory electrics also include backup lights and rear fog light. The connector is 7 pins and I really doubt there's, for example, a "U-haul" adapter.
Most USA trailers use same bulb filament for brake and turn indicators, and this requires some extra electronics to avoid turn indicator being always 4-way hazard flasher.
