E-Class (W211) 2003-2009
Recommend Code Reader and with CEL Reset?
Old Oct 1, 2010 | 08:05 AM
TPAbnz's Avatar
2017 E300W
I've read lots of posts here about fault code readers. I'm not looking for something sophisticated, just something cheap enough to read the codes and that can reset the check engine light.
Thanks for the input!
Old Oct 1, 2010 | 10:01 AM
lsbrodsky's Avatar
2016 Jaguar FT-R
For a cheapy, you can just get one at Walmart. I upgraded to Autoenginuity becauseIi wanted to read many of the MB unique parameters, but the cheap units are fine for the standard codes.
Larry
Old Oct 1, 2010 | 11:12 AM
TPAbnz's Avatar
2017 E300W
Will the cheapies allow you to re-set the check engine light?
Old Oct 1, 2010 | 01:33 PM
lkchris's Avatar
'10 CL550, '12 GL550
Be sure you understand the concept of "reset."
Reset doesn't happen until the problem is fixed.
Old Oct 1, 2010 | 01:41 PM
lsbrodsky's Avatar
2016 Jaguar FT-R
The cheapies do allow a reset, but as lkchris said, the light will come back if the fault has not been cured.
Larry
Old Oct 1, 2010 | 07:57 PM
TPAbnz's Avatar
2017 E300W
OMG, thanks so much for the insight...I thought re-setting CEL would immediately fix my car without actually being repaired! Wow, I really appreciate your "concept" and setting me straight.
Old Oct 1, 2010 | 08:44 PM
AMG_only's Avatar
ML55 S55
Huh?
Old Oct 3, 2010 | 11:39 AM
starbrite's Avatar
2004 E320
He was being facetious.
Old Oct 19, 2010 | 12:33 AM
jhutagaol75's Avatar
2005 E500
hey guys,
do you guys know what brand or manufacture of the scanner that can read 05 E500? I have tried a couple scanner from $100-300 and none of them scanned my car. I appreciate your help and any links to buy it..
