E-Class (W211) 2003-2009
Airmatic Suspension 06' E350
Old Oct 31, 2010 | 05:39 PM
abctom's Avatar
2006 e350 AND 2002 ML320
I have an Airmatic Suspension on my 2006 E350. I raised the vehicle from the rear differential using the side lift points for my Jack Stands.
Rear brakes and rotors replaced with no problems!
Problem: When fininshed I lowered the car for a test drive. I heard yawning noises coming from the rear and when I got back to my house the rear suspension was completely on the ground.. There are no messages displayed or computer codes. The front end did not loose air. Usually when I put the key in the ignition and before starting I hear a compressor noise-this is not happening now!
Where should I begin to test?
Old Oct 31, 2010 | 11:11 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
I never knew E350s had air suspension? I thought it was a V8+ type of thing.......I think the problem might be you took out the lines for the air suspension or maybe you messed with the rear link......which is why mine was sitting on the ground too.
Old Nov 1, 2010 | 12:42 AM
abctom's Avatar
Airmatic on 06' E350
Airmatic was an option on the 06 E350 sport.
What is so frustrating right now is that I didn't touch the air lines. All I did was raise the care from the differential so that I could put jack stands to raise the rear end.
Old Nov 1, 2010 | 12:43 AM
djrabbi's Avatar
post up a picture....i want to see if it same problem as mine...when you drive it bounces all over the place right? like a lowrider?
Old Nov 1, 2010 | 12:44 AM
abctom's Avatar
HELP!! AIRmatic Suspension 06' E350
Old Nov 1, 2010 | 12:47 AM
abctom's Avatar
YES IT BOUNCES LIKE A LOWRIDER!! THERE IS NO REAR SUSPENSION..IT'S LAYING ON THE GROUND...
Old Nov 1, 2010 | 12:49 AM
djrabbi's Avatar
my problem was my rear link popped out so I had to place it back in place....this is only cause I lowered mine....I am sure something to do with the rear air lines...thats y never do DIY on my own! try searching, but I am sure the struts aren't failing cause you would have gotten a message on the dash.
Old Nov 1, 2010 | 01:11 AM
abctom's Avatar
The Suspension has worked just fine up to this point and as soon as I took a test drive it started to make a noise from the rear and dropped to the ground.
When I open the door the compressor doesn't come on.
The front end is just fine.
HELP!!!!!
Old Nov 7, 2010 | 10:58 AM
ThisSideUp's Avatar
e500
I have the same problem and have no cluse what is cauisng it. Dont relaly want to take it to the dealer and spend big $$$$ just to find out it is something I can fix myself!
