A night from hell feat. E500
The left side worked like a charm but the electrical connector on the right side just wouldn´t turn to "close" like it was suppose too.
After three hours of jiggling i finally got it in. The only way to get it in was upside down with the "Open/Close" facing down. Is this correct?
I also broke one of my bulbs so i have to get another one but the worst part is that lights won´t go on after i connect the battery back on. They are completely dead. The position lights and full beam is working though.
I have error codes for active headlights, leveling mechanism and the lights. I also found a disconnected cable in the headlights with a green wire. Should this be disconnected or did i somehow disconnect it?
Please help, i just feel like setting the car on fire and throwing my self of a bridge or something.
According to this manual it unplugs automatically when you remove the ignition module. http://tech.bentleypublishers.com/se...%20removal.pdf
