Airmatic: a little different problem
On my 2004 E500 I have a little issue with the Airmatic. It intermittently fails to keep the car aired up. I don't think I have a leak, because there are times that the car is sitting low the next morning, but there are also times that I have it parked at the airport for 4 to 5 days and it still sits at the right level. It is always the back, never the front. I had the diagnostics run at the dealership and they said no faults or warnings came back. The equipment under the rear axle looks in very good shape, the aluminum regulator boxes still have somewhat of a shine to it and there are no tears in the rubber sleeve. A buddy of mine suggested maybe a sticky valve somewhere in the system and if I would put maybe a few drops of airtool lubricant in it and maybe blow the system off, that might do the trick. I have worked with 18-wheeler tractors and they usually have a canister that holds an antifreeze / lubricant mixture and it would be something like that. However, I am kind of hesitant. First, I do not know where I can open the system to put some lubricant in and secondly I have seen in the past that chemicals that work in every other car suddenly have side effects in an MB. On top of that it might not even be the problem. When the car runs, the compressor kicks in regularly, usually after braking, but not excessively. Maybe the switch is sticky or it has a battery saving program in it. I don't know! Anybody has seen something similar? Any advice is welcome.
