Does your MY09 Passenger Mirror Parking Position Feature Work?
I'm looking for some way to prove this to my dealer so they actually try to enable the feature for me. MBUSA is zero help so far.
Thanks.
MB took it out because there were too many complaints about the mirror not returning properly when going back into drive. At least that's what MBUSA told me over the phone.
There is a workaround: just set the passenger mirror to show the curb and then assign it a memory number. Yes, you have to push the memory number yourself to get the mirror to dip and then go back up again, but it does work.....
You must 1st activate the feature, then memorize the "look down" position for the right hand mirror, then always leave the right side mirror select button pressed in on the drivers door. Then a second after the car is placed in Reverse the mirror will look down to that previously memorized position.
The feature was "decontented" for USA cars in '07 for MBUSA by MB Germany, due to numerous complaints about its sometimes erratic behavior. In 03-05 the E class was riddled with poorly performing parts and hideous Quality Control, and the 211's ratings plummented. It was done to eliminate complaints as a quick fix by hiding the option from view in the DIC so the user can't turn it on, and therefore cant be annoyed. There are people on this board who have found certain dealers who are savvy with the Service Department Laptop (SDS) make the menu choice reappear, and their mirrors look down function has been restored. No urban myth. It depends on a Dealerships skill and their desire to make a car have "non standard programming". The motor's still in the mirror so you can adjust it to see rearward, just the link to Reverse has been hidden from you.
My '04 DID have this feature and it behaved erratically. The workaround solution above works perfectly every time.
70k car without a simple feature that's been around for over 10 years. COME ON MERCEDES!
Can't I complain to BBB since the owner's manual claims to have a feature my car does not? Living in downtown Chicago, this particular feature is something I rely on to park the car. Manually lowering the mirror right before I park can be dangerous as I'm usually holding up traffic to park etc.
These sorts of feature issues really disappoint me as a car enthusiast. I truly love all the gadgetry which goes in to modern automobiles and it really seems like MB is constantly behind the curve. Yes, BMWs have more electronic related problems but they also have way more features available to the customer. Could be time to switch...
Okay, please tell us (or pm me) the dealer's name and your SA's name (and tech's name) so I can call them and ask how it's done. Thanks!
Good, now we have another person who said it was done at a dealer.
House of import in Buena park and Caliber Motor in Anaheim Hills coudln't do it!
The one lack of feature that is driving me nuts is the inability to do a one touch close of the sunroof while driving. Every car since my 93 Honda civic has had this feature. I shouldn't be forced to drive with one hand for 5-10 seconds because the other hand is holding the sunroof close button.
FWIW it is the holidays.. Stop by your SA with a little card and a bottle of wine. It really help to have a good relationship with your SA for stuff like this and to have someone who will look out for you for other issues that may come up.
I called MB Beverly Hills this afternoon and asked again. They told me that it's not that they CAN'T do it, but it's that MBUSA has told them NOT to do it. Apparently it's buggy and does still create issues (like it did in the pre-2007 models.) Eventually it'll get stuck in the down position and you have to go back to the dealer and reset it. Anyway, this is what they said. And that's why it was decontented to begin with. You'd think Daimler would just fix it instead of removing it altogether
See above. It's not that they don't know how to do it, but that they refuse. The bottom line is simply to find somebody willing to do it (the right dealer or an Indy with SDS.)
* A now deleted menu choice due to customer confusion.
When you're in reverse gear you can adjust the angle of the mirror how you want it. Once you did that press M to enter memory mode, then press 1, 2 or 3 (depending which number stores your personal settings) then press and hold M again for 3 to 5 seconds to store the settings incl. your parking position mirror setting. You're all set.
When you switch to D the mirror takes about 5 seconds to move back up. This is done that way b/c sometimes you need to go back and forth to park correctly and the mirror doesn't have to move up and down which takes some time.
