Class Action suit over M272 M273
#176
#177
Received 4,435 Likes
'71 Pinto
30 077021 is within affected range.
#179
#180
'71 Pinto
30 048889 is within affected range.
#182
'71 Pinto
273 idler gear of the chain drive needs replacement to modified part. Repair is covered under warranty however, MB will not approve repair unless fault codes are present. Out of warranty, MB has offered goodwill assistance towards parts & labor on a per case basis if fault codes are retrieved. Even if purchased from MB dealer, without fault codes doubt they will perform repair for precaution.
#183
The codes are present and I have placed a called into MB do you think they will help pay for some or all of this. What has been the outcome for others you know. Thanks you so much for your help
#184
'71 Pinto
Important factor for approval is customer loyalty. Importantly if there is a history of having past and/or present vehicle(s) serviced by MB dealer - routine maintenance, repairs, etc. as confirmed by Vehicle Master Inquiry (VMI).
#186
#187
'71 Pinto
Not applicable, only 272 & 273 engines.
#188
07 E350, 99 c280, 98 c230 Sold, 89 300 SEL Sold, 83 300TD Sold, 79 300D Sold
#189
Super Moderator
#190
Thank you............ looks like I am in the affected series........just bought the car two months ago with 49K on the odo. Looks like I will have to decide whether to keep it or sell it......feel like I am driving a ticking time bomb now....just waiting for a $5K repair......probably goes up for sale after the first of the year......
#191
#192
'71 Pinto
Not within affected range.
#193
Konigstiger could you please run WDBUF56X57B034613 for me so I could have a PDF of the output.....I know I am in the range and I would like to have the PDF for reference with the local mb dealer......thank you......
#194
'71 Pinto
Certainly...
#196
Received 1,498 Likes
#197
Safe Model Year
Im looking for a W211, preferrably with a V8. Before the face lift, we had the electric brakes that I don't want. Now, is there a model year of w211 that's less likely to be affected by this sprocket material issue?
#198
'71 Pinto
Clean points 272 (350) as of 10/06 production; 273 (550) 9/06 = avoid early build MY07, 08-09 fine.
#199
m273 sprocketissue
Hi everyone, was hoping I could get some help, probably off topic, my apologies.
I've been having some strange vibrations issues.
I've replaced the motor mounts twice, tranny mounts, tranny service, left and right front axles, coil packs,plugs, recently just replaced the drive shaft..problem still exist.
Was wondering if it could be this *recall sprocket issue?*
My vin is WDBUF90X27X216482
Is my car affected? Thank you in advance!
#200
'71 Pinto
WDBUF90X27X216482 Is my car affected?
