E-Class (W211) 2003-2009
04 Wagon folding seat stuck! Help!
Old Mar 27, 2011 | 10:00 AM
dirtyhands's Avatar
w201 190e 2.3 5spd + w124 300te m104 3.2
Hey guys just purchased a 2004 e320 wagon for the wife, got a good deal on just slowly working out some kinks here and there to ensure longivity, I went out the other day to fold the rear seats down, the passenger side will fold down but the driver side aka the 60% part will not fold down. It seems like a cable or linkage is disconnected. Is there a way to manually unlock the seat so I can gain access to the mechanism? I'm nervous to tear the leather up. I went on star to veiw breakdown, but I need to get the seat down. Has anyone else delt with this? Thanks in advance!
Old Oct 10, 2011 | 02:24 PM
apistomax's Avatar
2004 E320 Wagon
Stuck rear seats in 04 E320 Wagon
I have the same problem. Both my rear seat backrests are stuck. I spent two hrs trying to release them. I need to replace shock absorbers and can't remove the trunk panels to get to the shock absorber mounts. The plastic part of the driver side release latch looks broken and I see a L-shaped rod dangling in the release mechanism. Is there a way to release the lock without taking the whole backrest apart?
Old Oct 13, 2011 | 01:45 PM
apistomax's Avatar
2004 E320 Wagon
Nobody? I found a DIY stuck rear seat for a W210 but don't know if it's the same mechanism.
Old Nov 9, 2011 | 12:39 PM
rupped's Avatar
E320 wagon
I had the same issue with my car when purchased. If you have the cargo cover/dog net thing installed, you can not lower the driver's side until you lower the passenger side (and leave it down). Felt pretty stupid when I figured it out....
Old Nov 9, 2011 | 02:45 PM
willy_manilly's Avatar
2012 W212 | 2016 W205
I had the same issue on my W210 Wagon, the fuel level sensor was also bust and to get to it the seats had to be removed, however to remove them you have to fold them down.
I could never get them down therefore never knew how much fuel was in the car LOL
Old Nov 9, 2011 | 03:10 PM
apistomax's Avatar
2004 E320 Wagon
I didn't know that. Thanks.
My problem is that the latch on the driver side is broken and the passenger side latch doesn't seem to work.
I was able to peel the driver side trunk panel far enough back to get to the shock strut. I ended up cutting the shock out anyway. I still have to install the passenger side shock and hoping that I can peel that panel away enough as well.
Old Jul 21, 2020 | 03:31 AM
MSW211's Avatar
2004 E500
