E-Class (W211) 2003-2009
Rear turn signal bulb
Old Apr 5, 2011 | 03:06 AM
chisler's Avatar
E350
does anyone know the rear turn signal bulb type for a 2009 E class?
Sylvania does not say.
Old Apr 5, 2011 | 07:47 AM
06e320cdi's Avatar
2008 ML320CDI
I believe according to the manual you have to replace the entire light assembly. At least thats the way it is with my 2006.
Old Apr 5, 2011 | 08:59 AM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
x2
Old Apr 5, 2011 | 12:32 PM
lkchris's Avatar
'10 CL550, '12 GL550
Yeah, it's not the lens but rather the "board" to which bulbs are soldered.
Old Apr 7, 2011 | 04:19 PM
SAguirre's Avatar
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
Yep, you don't need to replace the plastic lens, but the bulbs are soldered on to a little board and they are ALL TOGETHER. I have LED brake lights, but the other lights are all on one panel. I think that one panel is about $50.00
They are supposed to last a long time, I'm surprised that yours burnt out! You should have the other bulb still operating, right? The W211 has two blinker bulbs in the back.
Steve
Old Apr 9, 2011 | 02:21 PM
charliele729's Avatar
09' E350 AMG Sport, 09' C300, 03' Honda S2K
Ok just to cofirm here, so turn signal bulb in the back are not replacement bulbs, but instead it a whole board that needs to be replace. I was thinking of swappin out some led bulbs for the turn signal.
djrabbi's Avatar
yeah you cannot....MB wins.
Old Apr 12, 2011 | 05:41 PM
SAguirre's Avatar
The only way you could do that (which would be a nice idea) would be to solder in an LED cluster and make sure that it has the same resistance as the two bulbs. Easier said than done. You will have a lot of errors if you don’t do it correctly. I think that before long, there might be an aftermarket company who will sell a little replacement panel that will pit in the place of the current “long life” bulbs and have it work without fault. It might be pricy though.
Steve
Old Mar 25, 2012 | 09:41 PM
E365's Avatar
BMW 318ti
I just replaced a welded-in PH16W tail stop bulb with a 921 / W16W bulb. It would have been a super-simple project if the stock bulb was soldered in and not tack/spot welded. I ended-up twisting the old bulb (don't pull at all) until the leads broke loose at the bulb. You can then pull out the black base, which leaves about 1/4" of wire still attached to the circuit board tabs. I used a Dremel + cut-off wheel to remove the existing lead wires. Drill a 1/16" hole in the circuit board tabs, straighted the lead wires on the 921 and just solder it in place. I did use a little hot glue to make a new bulb-base so the lead wires were not the only thing supporting the bulb.
I just tested it out in the dark and it's impossible to tell it's not a stock bulb.
$3 project.
Old Mar 26, 2012 | 04:23 PM
XLR82XS's Avatar
2006 E500 4matic wagon
LED assemblies are a great solution. There are at least 2 options that I am aware of for the wagon. Dectane lighting and eBay.
