E-Class (W211) 2003-2009
ESP malfunction, won't start no idea, DESPERATE
Old 11-15-2016, 12:55 PM
  #51
btv94's Avatar
2007 E350 RWD SP1 (M211.056/E272.964)
Originally Posted by raito00
My problem SOLVED
Today i received back Engine ECU and no more problems!
it was a Engine ECU problem!
Can you provide more info on the repair? cost and down time. it may help other.
Old 11-15-2016, 01:17 PM
  #52
raito00's Avatar
W211 E320 ,05
Unfortunately i don`t know exactly what causes problem on ECU and
guy told it is his company secret, i can understand him ...
Repair cost - 150 EUR
Old 12-14-2016, 10:06 PM
  #53
jettskiman's Avatar
2005 E320 CDI, 2011 ML350 4Matic
Ok I took it to the dealership on Oct 26th. Just got a call today saying it's fixed. They replaced the SAM because it kept eating relays, and that didn't fix it. They the CDI Module. I guess that did it. Anyway its snowing today and tomorrow so I wont be able to get it till Friday. I'm attaching the invoice so you guys can feel the 2850.87 pain with me. I guess my EGR valve wasn't compatible with the new module so I had to buy one of those also. Got a deal on parts and labor I guess and they did let me drive the new 2016 C300 for the last 2 months. Thats always nice. Good luck to the rest of you guys fighting it.
File Type: pdf
File Type: pdf
Old 02-04-2017, 07:11 PM
  #54
Elmar Shahverdi's Avatar
Mercedes E class w212
My w212 has the same problem. When i press the throttle all the way up it appears
Old 02-04-2017, 07:14 PM
  #55
My w212 has the same problem. When i press the throttle all the way up then "ESP not avaliable" appears.
Old 02-06-2017, 11:29 AM
  #56
edtse88's Avatar
2003 E320
I had the same problem and I fixed it after cleaning my MAF and noticing a loose connection under the MAF. I have a feeling it was that loose connection because my car would go into limp mode when I step on the throttle hard. I think the movement of the engine moved the loose cable just enough to lose connection.
Old 02-11-2017, 07:00 PM
  #57
sergionovo1960's Avatar
1998 E320
Same problem with my 2005 E320 CDI
Old 04-25-2017, 07:35 PM
  #58
Desmond White's Avatar
S430 w220
Originally Posted by JonnyWalker
This exact thing JUST happened to me and I posted about it. The dealer replaced my SAM (Signal Acquisition/Activation Module) and the ESP module.
Did this fix the problem?
Old 04-25-2017, 09:20 PM
  #59
jettskiman's Avatar
Ya it fixed mine. It was pretty spendy. Look at my post above for the invoice. On one hand I think these boards should have been built a little better. On the other hand I guess 12 years is a decent lifespan for something getting hot and cold over and over and power off and on all the time. It hurt to pay it out but I still love this car every time I put my foot into it.
Old 07-24-2017, 06:36 AM
  #60
Jackman1962's Avatar
2002 Mercedes Benz E240 (w211)
Ignition on but no crank. Cooling fan operates at high!
Check voltage of auxilliary battery located on the passenger side firewall. If voltage of aux battery is beyond 12v then check the front SAM relays. You can interchange similar relays 3 black square, 3 black rectangular and 2 gray square. If this does not work, try cleaning the connectors of the front Sam. Or you can test another front Sam front another unit of same model. If still does not work it could be your ecu. In another case if there is no crank and fan does not operate, it could be your park neutral switch. Or your brake light switch. Or if your too bz ask someone to use a Star diagnostic and let him interpret the fault codes in laymans term!
Old 08-22-2018, 05:55 PM
  #61
dkbkl's Avatar
X204 GLK 2014 / CLS C257 2018
So, easy fix for me. My MB 2007 was running high on fan speed, "ESP not operative, check owner manual" and no cranking when wanted to start it. Very upset, tried a lot of things, nothing worked.
The problem was a fuse, 25A in the front of the car, the one for fan. Blown. Change it and everything got back in order. Hope that helps
Old 07-07-2019, 06:32 PM
  #62
Brian Smith's Avatar
2005 Mercedes e320 cdi
Help! Same issue
Originally Posted by chemo
2005 w211 e320 cdi 80,000 miles
3 months ago stranded me at work with ESP malfunction/ABS malfunction. Would not start. Went back later to get it ready for tow and it started up and did well for about a month. No limp mode, just normal operation. At that time, the car did not show any codes on the dealers computer but it was running fine at the time.
Then 10 weeks ago it happened again, but this time it would not restart and displayed ESP Malfunction (but not ABS malfunction). It has been at an independent authorized mercedes service center since, including 1 week at a real dealer. The independent says it was the computer and put a new one in and it did not work, though there were some issues with coding the new computer but they were ironed out. It was towed to the Dealer by the independent (1.5 hours away where I bought it) and they worked 2 hours on it and said the comptur was not hooked up properly and it was DRIVEN back to my town. Then it wouldn't start and it sits at the independent still not starting demonstrating ESP Malfunction.
Everything else works. Just will not crank. Now week 10.
I am told the battery is in good condition, replaced last year, and making good charge.
Bit of history:
About 4 months ago, new brakes
About 3 months ago, horrible rev dependent vibrating sound that turned out to be a broken catalytic converter with a "dent" on the top, the side facing the inside underbelly of the car, and was told it was my fault and not a warranty issue. Fixed by dealer. I think in the process several other things were checked like the "shift sensor" or something but that was not it.
Except for a leaky high pressure fuel line when I first bought it in 2004, the car has been flawless.
I love Mercedes, I have had a 1977 240d during highschool and college, 1965 230sl, a 1997 c230, a new 2011 w212 e350 estate for the wife. But I am at my limit.
I have tried my best to read every thread regarding ESP Malfunction warning but none seem to fit my situation. Any point in the right direction.
Hello I am new at this and realize this thread it old but these are my exact symptoms. Did you find the problem? Thanks
Old 05-02-2023, 01:21 PM
  #63
ajai's Avatar
2003 e240 w211 v6
Originally Posted by etihad
My 2005 s500 not starting, and the star machine could not identified the cause, suspecting sam can B because the power supply where not circulate. Please I need urgent help
i had same issue e240 w211 v6 engine..my car is right hand drive..
Old 05-02-2023, 01:33 PM
  #64
raito00's Avatar
W211 E320 ,05
99,9% problem is in Engine ECU ... need resolder some small parts. Sorry but i dont`t know witch one ... My local chip tuner guy fix the ECU and no more problems.
ajai (05-02-2023)
Old 05-02-2023, 02:11 PM
  #65
ajai's Avatar
2003 e240 w211 v6
thank buddy..but i don't where the ECU location..is being on the front side with SAM
Quick Reply: ESP malfunction, won't start no idea, DESPERATE
