please pleasr help w211 e240 misfire under load
- Ignition angle.
- Injector timing.
- combustion time.
- Knock sensor (ignition retarding)
With all the parts you've replaced. I suspect a faulty injector/ fuel delivery, Have the mechanic switch the injectors to see if the misfire moves to another cylinder.
Have you monitored the Actual values?
Please provide the VIN number if possible.
Its a B**** of a problem, But hang in there..
1 - Injectors, Perform the Injector tests (monitor cylinder 4)
2 - fuel related:have you had any work done on the fuel pump/line/rail/filter ?
If so, please states them.
3 - Read the adaptation values for each cylinder and observe high deviations in cylinder 4. reset and perform self adaptation.
4 - If you've replaced the ignition coils (its actually stated as NOT a remedy), test the ignition module.
5 - Check function of crank position sensor (also visually inspect)
6 - Check Fuel Pressure and capacity.
above 4500 rpm, it misfire.
heading to the dealer on monday at 9 am.
Check your O2 sensor on the cats...I have added an H pipe and removed my secondary cats and resonator and the problem started IMMEDIATELY after.
My car is going into the shop for this today.
