E-Class (W211) 2003-2009
#### HELP !! HELP !! HELP !! ######
Old Jun 7, 2011 | 08:33 PM
gavin.y's Avatar
Sup, guyz.
It's such a pain after i took my E500 (2003 w211) to a full inspection, and mech told me that i need to spend 8000 totally to repair the car. The car was fresh import from Japan last year and i took it early this year from a dealer. I used to drive nicely and the fact is this E500 only travelled 45k kms so no wonder i did not do any inspection until now i need to sell it.
The inspection report lists some oil leaks and noises from the engine and crankshaft. Please have a look of the report and give me some suggestion on whats must be repaired before i put it on the market.
Actually the only problem i found out by myself is the noise from brakes when i was driving slowly. Also i can feel the vibration on the pedal. Is this some kind of problems from the SBC system? But why it is not on the report? What i must do to fix it ?
Actually, it's been a very nice car to drive other than those problems listing on the report. I do not feel any problems at all! I am concerning on the reliability of the report also!
Thanks a lot, guyz.
Please help me since i am fresh to MB.
Old Jun 8, 2011 | 07:29 PM
PlatinumPi4u's Avatar
06' w211 E500 Sport
The 2 motor mounts (and 1 tranny mount which you should do at the same time) is an easy do it your self, with a DIY post around here showing you step by step.
Same for the crankshaft pully / alternator belt / idle pully: also easy to do and a DIY is here.
Oil leak from valve cover gasket is fixed by replacing valve cover seal
Everything else I'd get a second opinion - this person is trying to rape you.
Old Jun 9, 2011 | 12:57 AM
gavin.y's Avatar
thanks a lot mate. You just saved me 8000 dollars~!!
Can u tell me where i can find the DIY please?
Old Jun 9, 2011 | 01:57 AM
vaaliant's Avatar
2007 E63 AMG
FYI for the rear shock thread I know some dealerships charge in the $2-3k range for doing this sort of repair:
https://mbworld.org/forums/e-class-w...-absorber.html
But I also would urge getting a second opinion on the other items as well
Old Jun 9, 2011 | 12:51 PM
06' w211 E500 Sport
Yes, they are here at mbworld.org - simply use the search function
Old Jun 9, 2011 | 06:59 PM
gavin.y's Avatar
wow~ 380 dollars to DIY and they dare to quote me 3000~~
OMG, I will start from the rear shock tomorrow.
So you think i could just leave the rest issues there, no need to do anything hm`?
Give me some suggestion on where i should start from please. I guess those mounts are the eazy ones?
Old Jun 11, 2011 | 10:50 AM
vettdvr's Avatar
03 E500 and Corvette
Rear shocks $3800? WoW.. I did mine and parts for both rear shocks (airmatic) were around $900 + shipping. I thought that was high but I now have new rear shocks.
The idle pulley is about $22 at autozone and uses the same bearing as the OEM part. I checked. Bearing has same co and part number so why not save $30 and spend the $22 or so at autozone.
The estimate you got really is HIGH !.
Don't underestimate the ball joints though I replaced mine at 65,000 miles and they have been known to fail earlier. You can DIY on this also but I let my dealer do this one.
Old Jun 12, 2011 | 12:26 AM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
$8000 ?! Find a good indy shop the cost mine be only 30% of it !
