E-Class (W211) 2003-2009
xenon headlight conversion
Old Jun 19, 2011 | 09:28 AM
03e55's Avatar
03' E55
My stock halogen headlamps are badly yellowed. I spotted these headlamps on ebay and am think of trying them. They look pretty good and are a couple hundred cheaper than the new OEM halogens off of ebay. See Link
http://cgi.ebay.com/ebaymotors/2003-...Q5fAccessories
What is it going to take to make these work? Does my 03 have auto leveling
feature? Do I just need an aftermarket HID kit that works with D2S bulbs?
Old Jun 20, 2011 | 07:58 AM
SwedeE55's Avatar
2001 E55 AMG, 2004 E320 CDI
You will need OEM ballasts, and activate Xenon in Star to make it work. Then it is just plug & play.
Old Jun 20, 2011 | 06:40 PM
03e55's Avatar
03' E55
I found the oem ballast on ebay fairly inexpensive. I think I also need ignitors. There would seem to be some wiring missing as well?
Found the Ignitors
http://cgi.ebay.com/ebaymotors/2003-...item19c4e16462
OEM Ballast
http://cgi.ebay.com/ebaymotors/NEW-O...Q5fAccessories
Old Jun 20, 2011 | 11:37 PM
hx_guy's Avatar
2017 E300 • 2016 Tesla Model S 75D
These are not for your car. If you read the description, it says...
2003-2006 MERCEDES-BENZ W211 E-CLASS
CRYSTAL ///AMG E63 FACELIFT STYLE XENON HID HEADLIGHTS
FOR WITH FACTORY XENON MODEL (WITH D2S PROJECTOR HOUSING)
COMES WITH AUTO-LEVELING MOTOR (x2 NEW 8000K D2S BULBS ARE INCLUDED, BUT NO XENON BALLAST WILL BE INCLUDED,
YOU WILL BE USING YOUR STOCK ONES), WITH AUTO-LEVELING MOTOR!
CHROME HOUSING WITH PROJECTOR WITH GERMAN MADE PROJECTOR LENS.
These are for cars that already have Xenon and want to change them to the 2007+ look. It even says further down in the auction...
IF you have Factory Halogen (Non-Xenon) Headlights:
* For the Non-Xenon equipped car owners, please look our other auction for that setup.
Old Jun 21, 2011 | 04:29 AM
SwedeE55's Avatar
Well, it will work if he wants a OEM style setup with D2S xenons instead of a cheaper aftermarket H7-xenon kit. It needs a little more work, and is a bit more expensive though.
Old Jun 23, 2011 | 11:16 PM
03e55's Avatar
03' E55
Lots of views and no replys. Apparently, I have to be the guinea pig here. I just ordered the lights, ballasts and ignitors. I'll post up when I have this all figured out.
Old Jun 24, 2011 | 04:09 AM
SwedeE55's Avatar
The Xenon setup on pre facelift is quite simple. Just plug it in and it should work. All you need to do except that is to enable Xenon in Star, else it will probably flicker or not ignite at all.
The auto leveling is controlled by the same sensors as the airmatic.
Old Jun 26, 2011 | 09:54 PM
03e55's Avatar
03' E55
Swede thanks for your replys here. Keyword is should work. I think that is all I will need to do as well. I saw a couple threads on other mercedes boards, a w204 and a Gl, where they had swapped them easily and just reprogrammed xenon=present. So I should be fine. I'll post up before and after and any issues that arise. So everyone knows for sure.
Stuff will be in this week, but I need to have the bumper fixed and repainted as well, so it may be a couple weeks.
So far I'm in for:
$405 for lights
$275 New OEM ballasts
$80 New OEM Ignitors
$100 Phillips D2S 6000k ultinon bullbs
Old Jun 27, 2011 | 02:22 AM
SwedeE55's Avatar
Yes, should work is the word. I haven't done the conversion myself since I've already got bi-xenons with active cornering. But when looking in to the possibility to upgrade them to facelift units (doing my E63-conversion) I understood that it should work like that on pre facelift.
Good luck and keep us posted.
Old Jun 28, 2011 | 04:29 PM
chisler's Avatar
E350
i had an hid kit installed over the weekend. the 55w ballasts had flickering but then they tried the 35w ballasts and there was no flickering. i guess for 55W ballasts you need to set xenon present?
Old Jul 2, 2011 | 11:39 AM
Dexion's Avatar
03 E320, 03 Lexus RX300
I think its the other way around, halogen setting should be 55W so if you have the setting on Xenon only 35W should be fully compatible.
