wipers wiping too much?? and/or noisy??
so i put the car in drive with full brake engaged and turn the wipers on auto. sprayed water on the water sensor. noticed my right top blade was not getting all of the water off like the middle or bottom. this is the part of the right blade that wipes over the water sensor. i bent that part of the blade alittle and now the blade wipes all the water off. the next rain will tell me they work better.
is there any fix for the wiper squeaks?
The dealership replaced them (the whole unti) and they were fine for about 12 weeks. Now they are unbearable again - in rain they judder up the screen, and return back quietly. Cleaned the screen and blades but to no effect.
Another new set ordered and being fitted soon.
Marc
Bottom line is that my wipers sound/ wipe smoth as silk. Quiet and errorlessly.
Could the Zaino have helped? Irealize the sensor issue may be different altogether, but I have a hunch thw wiper noise is helped.
I got a 2003 c240 as a loaner this week while my 03 CLK 500 was in for service (my wipers were changed too and thet are still loud) the wipers on the c240 were very quiet and smooth and it rained for three days, lite and heavy and they worked great in all conditions. MBZ should have never changed the wiper design from the w210's and w208 until the new one was perfected. My service adv said the S class also suffers from this problem!
I then put some Prestone Windshield Wiper Restorer on the blades that I've used in the past on other car's wipers. You put it on with an applicator that is included and let it dry for a day or more. It's important to let it dry BEFORE you move the wipers.
I put it on and forgot about it until it rained about a month later and I had to use the wipers. PRESTO, they were silent and worked fine. I've used them several times since then with no problems. Recommend you give it a try.
I believe the problem is that the new rubber blades are stiffer than those used in the past and tend to make noise at the end of each stroke unless the surface is smooth. You can, therefore, approach the problem from two ways. Smooth out the windshield which is time consuming or lubricate wiper blades with a product such as Presone Windshield Wiper Restorer.
I'd be interested in hearing if others have used this or other products with success. Since I'll be getting a new 2003 in July with the Nav system, I will be checking to see that this and about 12 other minor problems I've had with my current E-500 have been corrected before taking delivery of the new car. Overall, however, I'm VERY satisfied with my car
This really is amazing, having to wax our windshields to stop noisy wipers on $50,000.00+ cars!! this is
If the new E-Classes have the same wipers as the S-Class, they're about $125 a blade!
Get 'em replaced free while you can!
Marc
[B] Eventually I insisted they change the WHOLE wiper arms, as in my opinion the spring was too harsh, forcing the blade onto the screen. Thankfully new wiper arms cured it .
Dear Marc,
Is changing the wiper arm a ONLY cure to noisy wiper? Mine is a 2003 model.
Many tks for your advice.
B.Rgds.,
Steven
Marc
I had the whole wiper arms changed on friday to try and cure this, but it is still exactly the same, judders across the screen!
I had a similar problem on my old car (non MB). I was advised to use toothpaste to clean the grease and other deposits off of the screen. I thought it was a crazy suggestion and ignored it for months. However, in complete frustration, I eventually tried it. It worked a treat.
I am NOT happy for mb low quality wiper/blade.
this obviously is a recall item but mb does not want to do it for free. shame on mb. (can someone confirm that this only happens in the cars in usa?)
toothpaste, hmmm. Its funny how many times i have been suggested to use that for various things, from facial cleansing to now windshield cleaning lol.
I wouldnt really recommend toothpaste due to its inconsistencies in abrasiveness. Get a real glass polish like Zaino Z12, toothpaste may infact be too abrasive for todays soft cheap glass. BTW, you guys should really try PPG aquapel. It really makes wipers operate smoother and repels water like a dream!
