E-Class (W211) 2003-2009
BI-XENON leveling faulty
Old Aug 17, 2011 | 03:57 AM
19657's Avatar
S211 E220
Hi,
it happens that my right side auto leveling is not working... or is stuck at minimum. Just noticed today...
It is a end of 2004 E220CDI T
When I turn on car, left side runs self check down and up, while the right side does not.
Since the car usually starts at middle then down then levels, I could think that it ran out of reels ?!? when checking low heigth?
Any help?
Old Aug 17, 2011 | 07:54 AM
edusyl's Avatar
2006 mb e350-,2019 glc amg43
This happened to me before, and the problem was a low battery charge .
Old Aug 17, 2011 | 09:38 AM
19657's Avatar
S211 E220
And only the right side?
Old Aug 17, 2011 | 09:52 AM
edusyl's Avatar
Yes, it was only the right side. I took the car to the dealer ( under warranty) and They told me to drive the car for several miles to recharge the battery. Because I don't drive this car enought ( 2500 miles per year) I had this problem more than once. Since then I drive it every weekend for around 30 miles and the light are working fine. I hope this helps.
Old Aug 17, 2011 | 02:36 PM
WEBSRFR's Avatar
Tesla Model S P100D
Life is so tough for you... You are forced to drive the E350 once a week
Old Aug 17, 2011 | 06:27 PM
19657's Avatar
S211 E220
But I just came this weekend from a long trip... at night.. but over 300km.
Is there any test we could run?
Old Aug 17, 2011 | 09:27 PM
edusyl's Avatar
This happened to my son, right light wasn't moving, so He pull it up with the adjusting screw and since then no more troubles. May be was stuck?
Old Aug 17, 2011 | 11:57 PM
JeffyPooh's Avatar
2017 GLC43 'AMG'
I've noticed that on my E350, the right active bi-xenon headlight dips down and back up right after I start the engine, but the left is not doing anything. I'll be asking the dealer to investigate the discrepancy when I get a chance.
Old Aug 18, 2011 | 02:14 AM
Diesel Benz's Avatar
It is the self levelling motor at the headlight that gets stuck. Officially the fix is a new headlight unit.
Old Aug 18, 2011 | 03:23 AM
Prm's Avatar
Prm
E280cdi Sport
Also check the self levelling units on front and rear anti-roll bars, the small arm sometimes breaks
Old Aug 18, 2011 | 06:39 AM
19657's Avatar
S211 E220
If it was the control arms, then both would not move, right? or it has sensor for left and right side?
Old Aug 18, 2011 | 10:09 PM
Dexion's Avatar
03 E320, 03 Lexus RX300
If you need a new headlight unit, get em off Ebay, Depo lights that mimic the OEM ones to the T, only cost $440 for a pair, just supply your own ballast.
Old Aug 20, 2011 | 10:46 AM
rody45's Avatar
E200CDI T W211 year 2006
Low batery ?
You dont hav to run the car to charge the battery. That would be an expencive way of doing it. Just connect a battery charger sometimes during the year. Or use a charger with a maintenance program that keeps your battery folly loaded all year around.
