To Charge Aux Battery ??
The main battery in the trunk appears to be sealed with a label stating: VRLA Battery Do Not Open. There are six caps on it but a screw driver or knife will not open them. Their design is unusual for a screw type cap. All labels on it indicate that it was made in Germany. If the aux battery was low on H2O I'm positive that this one could use some also. Any ideas/comments?? Thanks...
tarheel76
If it was me, I'd replace both of them. But it's your choice.
tarheel76
tarheel76
My '03 E320 has AGM technology for both batteries, so I don't know why you're putting water in the aux.
I've replaced both in the past -- main battery was from Napa (Deka) and the aux I bought from the dealer -- there are posts here where people have identified AGM motorcycle batteries for the aux replacement with same size/properties. Replace AGM batteries with other AGM technology -- don't put a wet acid (aka "flooded") battery in there as the charging rates are different and the wet acid battery will cook and eventually fail.
BTW, when you're playing around with disconnecting batteries, make sure things that are set on automatic (i.e., headlights, wipers, etc) are turned off before battery work.
Regards,
paul...
My battery was the original with 90,000 miles and 7 years on it.
Last edited by sct1965; Oct 28, 2011 at 03:54 PM. Reason: forgot something I wanted to say
