E-Class (W211) 2003-2009
brake.
Old Jan 9, 2012 | 10:32 PM
osos1's Avatar
e550 sport/2007
Question brake.
how to cleare a message after changing pads and rotors on E550/07
thanks
Old Jan 10, 2012 | 09:23 AM
vettdvr's Avatar
03 E500 and Corvette
thanks
?? What's the message?
Old Jan 11, 2012 | 02:09 AM
osos1's Avatar
e550 sport/2007
breaks
hi
the message is(break pad wear)
thanks
Old Jan 11, 2012 | 08:51 AM
vettdvr's Avatar
hi
thanks
Most of the time the wear alarm is due to a defective sensor or not plugged in securely. The sensor is just a loop of wire that is cut when the rotor wears through it.
If you changed the sensor with new and plugged it in properly it should clear after enough cycles.
