Transmission Neutral after kick-down
had this happen to me 3 times today!!! once while i was on a ramp going up!!!!!! luckily no one was behind me and i was able to safely back up to level ground but this is really disappointing!!!!
i just had transmission fluid flushed and changed to performance oil (redline)... would this have caused the transmission problem....
aside from that, ive had several experiences wherein the transmission just wont shift up after going through an incline... for instance, after i climb an incline and reach level ground.... the transmission just seems to be stuck in first gear without shifting...
my solution would be to shut off the engine and start it back up again...
benz and its computers..... i would expect for the premium that you paid for it.... they would at least give you a decent transmission!!!!!
anyways, enough of the whining... was just wondering if you guys have found a permanent solution to this yet?
thank you
The car operated fine but when I gave it gas and kicked down, the car would respond as usual, but return to neutral once the passing phase was over - didn’t do it all the time, but often enough for me to notice and take it in.
The transmission had a leaky seal around some electronic component, whether just low fluid or low fluid plus interference with the electronics I can’t say, but that was the issue. The leak was so slight that there were no obvious signs of an issue, and without a transmission dip-stick, no way to check the fluid level either. Going into neutral was a safety feature, and also triggered the check engine light but did not produce a code. The light would go off by itself after three starts or so.
i will show this to my mechanic, and see how we can deal with this problem.
this message also showed in my screen this morning right after i had the transmission problem.
i also took a video of the problems i've encountered with this cars transmission so that i could show it to the mechanic... hope they could solve the problem as it really is becoming quite a pain in the rear...
http://www.youtube.com/watch?v=OGeFcCRDSOM
http://www.youtube.com/watch?v=UScaWR_elKE
Codes come up that say misfires...
