Transmission Neutral after kick-down
This morning I floored to pass a car (you have to be quick in these 2-way road), I went from 50 to 75 mph as quick as usual. After I has pased the car released the accelerator, (was approaching a curve and had to reduce speed to 65 mph to enter it properly). In the moment I relased accelerator and touched brake felt a like bump, and the car was going Neural. The stick was in "D" and so was displayed on the dashboard, but no power was trasmited to the wheels.
I stopped the car, swhitched to Park and then again to Drive position, accelerated and the car began to move like if nothing had happened.
This afternoon the car has entered - for the 1st time - the dealer shop. I feel unsecure thinking it can happen again. Imagine it happens before I finish passing the other car .....
Any idea of what could be wrong????
After +2 months of ownership here is the first serious problem with the car.
The EXACT same thing happened to me about a month after I got me E500. Except I was getting on the highway during heavy traffic and the transmission would not provide any power. Asa result I almost got rear ended by a dump truck. Luckily, I didn't get hit but got me scratching my head. I pulled over to the shoulder and I was still in "D" and no power. I did not take any actions, after a minute the power came back. Knock on wood, this was the only incident. No resolution, it just never happened again.
Maybe we are in front of a - rare to occur - bug in the tranny software.
Talked him about the "drift to the right" issue and told me all W211 do that, anyway will test if it is out of specs. But no hope, cause he says it is designed to be as it is.
Keep you posted.
if you stop on a slope (30 degree up) without pressing brake, your car will slip back (in D gear S mode) -- give her a brake, this is in "D" gear? Do I drive a manul car? give me a break. (solution is using "W"inter mode, but I am NOT happy w211's tranny at all.)
Talked to the chief of mechanics about the issue and He said no problem nor strange values were registered while he drove the car.
Anyway he wants to replace a piece, an electro-hidraulic actuator he thinks could be the piece who produced that problem. I´m appointed for next Monday.
He seems very proffesional - You know german engineers come here (V.V. Motors, Granada, Spain) to test the cars. I saw the W211 wagon in October 2002 when I was to order mine.
I just bought an e55 1999 with 55k on it. When driving it home, I went to pass at about 60mph the trans attempted to downshift and then bam nuetral. I had to coast across four lanes of traffic as there was no left lane shoulder. I put the car in park and then drive and it drove fine. Also when manually shifting from 1-2 there is a great hesitation almost a nuetral situation for a couple of seconds and then it kicks in.
I read about this problem in another forum and the owners there stated the fix was corrected with a new clutch pack and software config. You may want to bring this up and or suggest a possible fix of this nature. Please let me know what their response is as I would like this problem correct too.
I don't think the tranny is going to neutral - it does *feel* that way though. My theory is that the tranny programming is just like the brake pedal programming. Overdone.
They were working on the road, so i was driving very slow.
After that i did a kick down and the car got into neutral.
Its my third time in 30.000 km now.
The dealer allready changed the computer but it's still the same
My car is a 220 cdi c class automatic
But, since that is kind of stupid; this is what someone has to do:
Have a camera that can take short video clips. Most little digital cameras now can. Keep it in your call at all times. If this happens, then record a short clip of the shifter's position "D" and then pan over to the dash. While still recording, film the MFD showing that the tranny is in "D" and then make sure the rpm gage is visible. Then rev the engine a few times and prove it them!!!! While still filming, put it in park (and make sure the camera gets it) and then show them that the tranny engaged again. They will never duplicate it when they test the car it is Murphy's law.
But, if you bring a video without any scene cuts, then they cannot argue with it. My 1991 300E had a tendency to start right up and then stall immediately when it sat for one hour and it was hot. The dealer in Tampa said that everything was fine! I filmed it doing it 10 times with the time and date stamp. Then they fixed the DAM problem.
Video says a lot! This transmission problem is a safety hazard and could easily start a recall! If this happens to you, try to film it.
I personally started a recall on the 2001 Porsche Boxters :-). Long story
Steven Aguirre
Dlau
Steve
I think they had an internal service bulletin related to that issue.
If not, they couldn´t fix it properly at first try.
Any news on why it happens?
Rob
I didn't think it was as big of a deal as you guys did, but it could have been an issue. I don't want to take it to the dealer have them waste a week and tell me the counldn't replicate it. This is the first time I've had it happen.
-m
I know that if you are not moving (for example at a traffic light) in “N” position, and you try to accelerate the car just some milliseconds after sifting the gear to “D", the car will rev, but mot move.
(This has to be done in a very precise way, otherwise the gear will be engaged and the car will move).
This, I believe, happens as you try to accelerate while the gear has moved out of “N” but not yet entered into “D”, therefore the computer does not allow you to get onto “D” for some technical or reason (engaging gears at high rev from Neutral, or whatever).
If you apply this to a situation in which you are braking to get to a curve or road work, and the transmission downshifts because or RPM are low (not because you change gears by suddenly accelerating), and in the exact same moment the car is downshifting because of low RPM, you hit the gas, it is possible that the same things happens.
I actually have no idea, but it is something to think about. The traffic light issue happened to me once, but gave it no importance since it happened to me as well with my previous car (99 Sebring LXI), so I thought it was done to avoid other problems, as for example engaging gears at high revs, causing some problems in the gearbox.
