E-Class (W211) 2003-2009
URGENT: NHTSA Opens investigation into fuel leaks on the W211 E Class
Old 04-19-2013, 01:02 PM
  #201
AMGAffalterbach's Avatar
2014 BMW M235i
How is it under mechanical stress when driving? Is it supposed to be? I can see how that would create a problem.
Old 04-19-2013, 03:19 PM
  #202
StarvingArtist's Avatar
CLS 55 AMG E500 99 ML320
The cap holds the pump and sending unit from sloshing around in the tank.
Old 04-20-2013, 01:29 AM
  #203
2014 BMW M235i
Oh makes sense, alright. Dumb question I know but that clarifies it. I wish this wouldn't turn out to be a half-decade long "investigation" (which I'm sure it will be before it's settled) - I just don't know why the NHTSA/Mercedes will not recognize this problem. Other than the obvious answer of monetary considerations, I would think a company like Mercedes-Benz would want to protect their reputation above repair/replacement costs.
Old 04-20-2013, 07:27 AM
  #204
MBUSA blew me off with "out of warranty."
Old 04-20-2013, 08:25 AM
  #205
vettdvr's Avatar
03 E500 and Corvette
I'm not surprised. It's all about $$$$.
I have a new warranty.. with Chrysler.
Old 05-18-2013, 12:05 AM
  #206
Matthewq4b's Avatar
05 Mercedes E320CDI
Another leaky W211
Hello I have a 2005 E320CDI .
I had been having issues with diesel puddles under the car. And after doing some resaerch I seen this seemed to be a wide spread issue with the W211.
So I Filled the vehicle up with fuel the other night and in the morning there was puddle of diesel under the car. I removed the back seat and inspected the Fuel sending units under the seats and found the passenger side Sending unit (is just a block off plate in this car) was soaked with diesel and a puddle was sitting around it. I checked the locking ring and it was loose by hand it appears that it was never properly tightened at the factory. Or the design is such that is loosens over time. A complaint was filed with the Transport Canada
Old 05-18-2013, 07:50 AM
  #207
FWA E500's Avatar
2004 MB E500
RECALL FUEL LEAK -W211 E500
GENTLEMEN - JUST FILED. THANKS FOR THE HEADS UP.
MY 2004 E500 (70k MILEAGE) JUST STARTED NOTICING A FUEL SMELL IN MY GARAGE AFTER FILLING UP. NEVER DID THAT BEFORE.
HERE IS MY ODI NUMBER:
Your Confirmation number (ODI Number) is: 10512625
Old 05-19-2013, 12:45 PM
  #208
rudhar's Avatar
2006 E55 AMG
Add me to the list ODI: 10512696. last of vin A832834 2006 E55 AMG
Old 05-23-2013, 11:52 PM
  #209
0-60inAMG's Avatar
2004 MB E55 AMG
This is amazing, more and more Mercedes cars on the NHTSA site signing up with fuel leak issues and nothing has been done about it. When are they going to make this right?
Old 05-24-2013, 01:42 AM
  #210
2014 BMW M235i
Well they did change the status of the investigation a few weeks back so at least there will be continuing, more formal inquiry. Just be patient that's all you can do =\ none of us really know the answer for sure.
Old 06-02-2013, 12:34 PM
  #211
mtoadsix's Avatar
2004 E 500 sport
Fuel leak
Same as the rest of you!!! Sucks as this '04 E 500 is my wife's daily driver. 103+K on the car. Took the car to my local independent shop about 2 months ago to search and repair the issue. Found fuel around the sending unit under the drive side back seat. Looked like the seal was bad, replaced it. Seemed to help for several weeks then the leak was back. Filled the car on Friday, 5.31, parked in the garage Friday night and was knocked over by gas fumes on Saturday morning. Parked the car outside overnight. Just checked the sending unit again and a pool of fuel was again present. Moped up fuel to see if I could see where the unit is leaking from. It is not leaking from the ring, it is leaking from the top of the sending unit. The part where the small wire plug is attached to the sending unit. It looks like this part is "glued" to the body of the sending unit. I guess the short term fix is to only fill the tank half way. Dealing with the government, NTSB, and MB attorneys will take longer then I plan on keeping the car. I would have a hard time selling this car in good faith to someone with this issue. Glad I found the forum as I was about to spring for a new sending unit and seal......
Old 06-03-2013, 01:49 PM
  #212
ethanwa's Avatar
2007 E550
Filed.
Your Confirmation Number (ODI Number) is: 10514846.
Mercedes E550 2007
Old 06-04-2013, 05:13 PM
  #213
vettdvr's Avatar
Maybe you should have bought a FORD!
Ford Motor Co. (F) has recalled 465,000 vehicles globally in order to repair fuel leakage. 2013 Ford Fusion, Flex, Explorer, Taurus, Interceptor Sedan and Interceptor Utility, together with the 2013 Lincoln MKZ, MKS and MKT are the models recalled.
Ford will check the fuel tank leaks, which may result in fire. However, there are no accidents or injuries reported so far owing to fuel tank leakage.
Old 06-04-2013, 06:51 PM
  #214
vettdvr's Avatar
But then you could have bought a Jeep. DETROIT (AP) -- A defiant Chrysler is refusing to recall about 2.7 million Jeeps the government says are at risk of a fuel tank fire in a rear-end collision.
The National Highway Traffic Safety Administration sent Chrysler a letter asking that the company voluntarily recall Jeep Grand Cherokees from 1993 through 2004 and Jeep Libertys from 2002 through 2007.
Chrysler Group LLC, which is majority-owned by Italy's Fiat SpA, said in a statement Tuesday that the Jeeps are safe and it "does not intend to recall the vehicles."
Old 06-05-2013, 03:16 AM
  #215
2014 BMW M235i
Saw that today on the news and instantly thought about this thread. Moral of the story: it's ridiculous that this is an issue and should be fixed especially with a company like Mercedes-Benz that prides itself on the best of everything... but at the end of the day we are dealing with a FOR PROFIT COMPANY and it could be worse IMO...
Old 06-08-2013, 05:37 PM
  #216
ndh22's Avatar
350 glk 2010, E320 4matic 2005
E320'05
Have had the same problem with gas smell
Old 09-08-2013, 08:19 PM
  #217
DrBob's Avatar
Well the NHTSA is taking this seriously enough that, after I filed a report, they asked for copies of my service invoices, AND, sent a courier to pick up the used, leaking fuel pump module that I saved after the last time it was replaced. They said they are going to test it. They also asked for the photos that I had of the fuel puddling on the module atop the tank. So, if you're on the fence about filing a complaint, please do so now. This is NOT dead.
Bob Johnston
2003 E55
Old 09-09-2013, 08:53 PM
  #218
mechefan's Avatar
e55 amg 2006
Waiting on....
It seems that the deadline for mercedes to come up with an excuse on the gas leak is tomorrow, hope we hear something soon, keep your fingers crossed!!
Old 09-09-2013, 10:28 PM
  #219
2014 BMW M235i
Oh thank God. After a pretty extreme canyon run a few people from the car meet noted that they smelled gas from my car afterwards (I was on a full tank but have never had the issue to severely) and that worried me, I really want this recall done -_-
Old 09-10-2013, 09:51 AM
  #220
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Your Complaint Information has been successfully submitted.
Your Confirmation Number (ODI Number) is: 10542811.
Old 09-10-2013, 02:46 PM
  #221
novae500's Avatar
W211
Bob Johnston
2003 E55
I am shocked that NHTSA are going out of their way to investigate this. About time!!! Clearly something is wrong Mine is leaking again after not even 2yrs of replacing the driver side sending unit!
Old 09-10-2013, 04:05 PM
  #222
radaddict's Avatar
2002 CLK430 & 2007 E350
Had this problem on my wife's recently purchased '06 E350. I filed a complaint with the NHTSA, but replaced the filter/sending unit myself, which fixed the problem.
A couple of observations: The new unit is a slightly different design from the old. I purchase all the parts from a local MB dealer and they uncluded 2 new sealing rings along with the sending unit and new seal. Interestingly, I could not use the new rings; they were too tight to go on easily. I could have forced them on, but did not want to run the risk of damaging the tank, so I re-used the old rings.
I'm wondering if the sealing rings on some cars were incorrectly installed at the factory or when new rings are used when the filter/sending unit is replaced, thereby putting additional stress on the tank causing it to warp or crack.
Additionally, someone from the NHTSA called me to talk about the issue. He said the filter/sending unit is a maintenance item with a replacement schedule of every 65k miles. Sure enough the manual says to replace the fuel filter every 65k. Unfortunately, with this model car, the filter is part of the sending unit, so the whole assembly needs to be replaced.
Old 09-11-2013, 08:30 AM
  #223
novae500's Avatar
W211
May be a maintenance item every 65k miles, but i replaced my driver side unit at dealer for $900 around 58,000 and 11,000 miles later i'm getting the gas fumes again when i have a full tank of gas.
Old 09-11-2013, 10:07 AM
  #224
SPONSOR
loungn14's Avatar
looks like something is working...
Just got a phone call from NHTSA about my complaint and they are taking a serious look at it...
Old 09-11-2013, 05:37 PM
  #225
rolex11's Avatar
2007 E350
Discovered the fuel smell last week
Filed a complaint with NHTSA.
ODI#10543145
Mercedes E350 2007.
GregMB please add me to your list.
Quick Reply: URGENT: NHTSA Opens investigation into fuel leaks on the W211 E Class
