E-Class (W211) 2003-2009
HID woes
Old Jul 7, 2012 | 05:21 PM
greg12m3's Avatar
2008 EVO X GSR
HID woes
Hello, i'm installing an hid kit on a 03 e320, i have the capacitor(radio shack 272-1020) hooked up and when i turn the lights on they turn on and off, on and off etc. I think it may be the ballast, and also is there any need to change the fuse in the fuse box? I'm using a slim ballast picture below...
i've tried turning them on and i've tried turning them on with the auto feature with no luck..
thanks in advance for any suggestions
Old Jul 8, 2012 | 09:18 AM
Barry45RPM's Avatar
2015 ML 350
Is it necessary for the dealer to use SDS to mark HID=Present ?
Old Jul 8, 2012 | 11:14 AM
Tschuss_Bill's Avatar
2005 E320 CDI
I don't think so. That would be needed for Bi-Xenon setup.
Do you have 2 ballasts? Try the other one to see if you get the same result. This is not a fuse issue.
I'm a fan of wiring the juice from the battery by way of a harness/relay set up and not using the stock H7 wiring for powering the ballasts.
Are you getting the "on off" only when the engine is on? Do you have the polarity of the capacitor correct?
-Bill
Old Jul 8, 2012 | 04:19 PM
desired_speeds's Avatar
2007 SL55 AMG
dont bother with the radioshack capacitor. get a pair of those HID error cancelors and it should be fine.
