E-Class (W211) 2003-2009
Old 06-17-2015, 07:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering and Suspension Guides
Print Wikipost
Front shock replacement cost
Old 06-02-2013, 12:35 PM
nyoh2002's Avatar
2007 e550 4matic
Thanks. Any one know for sure about 4 matic and axle issue
Old 06-02-2013, 12:52 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
This video should help
Old 06-03-2013, 10:35 AM
Former Vendor of MBWorld
arnottdoug's Avatar
MERCEDES-BENZ CL-CLASS
Arnott Discount Code
Forum members can use code MBSAVE12 to save up to 10%* off the retail prices onArnott products for your Mercedes-Benz vehicle. You can place your order online at the Arnott Web Store or bycalling Arnott Customer Support at 1-800-251-8993 X 804 Mon – Friday from 8:00AM to 7:00 PM ET. Orders placed by 2:30 ET are typically shipped out the sameday.
*Max savings $75 per order, not valid with any other order or on shipping,taxes or core deposits (if any).
https://www.arnottindustries.com/par...33_gid518.html
Old 06-03-2013, 12:10 PM
nyoh2002's Avatar
2007 e550 4matic
Old 04-05-2014, 01:32 PM
hooligan's Avatar
E500 2004
Damn didnt see this till after i ordered...
Old 10-04-2016, 06:54 PM
spatemp's Avatar
E550
I have 2008 E550 about 82k miles and having issue with the driver side Air spring. Reading this thread is very helpful but had a few questions.
1) Driver side is sitting very low when car is parked but it comes up when the car is on and is drive able. I wanted to make sure before I replace the Air spring is that is this absolutely needs to be replaced. I checked the fuses and they are good. Since it is holding the air when the car is on, is there some other issue that I should check out before I replace this expensive part.
2) Do you need to do the alignment after the Air spring is replaced.
3) Lastly, any other suggestion. I have read here on this post or somewhere else is that it's good idea to do it in pair. But since the part is costly, I was wondering can I not wait until it becomes bad or is the suggestion is that it may go bad soon when you are on long trip or when you are least expecting.
4) Can anyone post the mileage that they got out of Arnott Air spring product(how long is it lasting). Just curious and trying to gage how many miles before this will go bad ?
Thanks everyone for you help.
Old 10-07-2016, 10:03 AM
  #32
dmpc06's Avatar
2018 S560 4matic 2006 E320 CDI
Make sure you do not have a leak at the connections with soap water!
Old 10-07-2016, 01:56 PM
  #33
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Make sure your pump isn't weak...
Old 10-07-2016, 02:17 PM
  #34
kajtek1's Avatar
Received 1,742 Likes on 1,389 Posts
1922 Ford Model T / no OBD
Weak compressor would not lift it quickly.
Would you have SD, you could read if the leak is in the system, or in the bag.
I installed pressure gauge on the line as I like to continuous monitoring.
You can inspect the bag visually. Pull the outside cover up and see how the rubber looks like.
When the rubber looks aged, get both sides new.
I remember one owner reporting Arnott bag blowing just few months after installation, but other than that owners are satisfied.
Lifetime warranty sure sounds good.
Old 10-07-2016, 05:10 PM
  #35
cmriv's Avatar
he asked for any other suggestions mfer
Old 10-10-2016, 07:58 PM
  #36
spatemp's Avatar
E550
Thank you everyone for replying to my questions.
Quick Reply: Front shock replacement cost
