E-Class (W211) 2003-2009
A/C red colour blinking button W211 E200 CDI- 2004
Old Jul 26, 2012 | 03:32 PM
slaweksawicki's Avatar
W211
Hi everybody i know that many users had same problem before but I never found any really useful answer to that thing.
After driving for 1000km suddenly A/C started blinking and shut itself off. We have checked freon (by professional) he said is more than enough, so we have found evaporator sensor - and it is also OK, so what could be the next step where to look for the fault (FUSES are ALL RIGHT) - is there any Relay switch in fuse compartment under the bonnet that could be gone? or how to get A/C A/C engineer mode on (2 zone AC) W211 E200 CDI- 2004 - The 5 sec REST button doesn't work. PLSSSSS Help
Old Jul 26, 2012 | 04:08 PM
konigstiger's Avatar
'71 Pinto
Attempt total reset - disconnect main battery in trunk, wait at least 5 minutes and reconnect. Afterward you may need to resynch windows (close and hold switch for a second or two), sunroof (tilt up and hold switch fort a second or two), and reactivate steering angle sensor (start engine and lock wheels from side to side then center it).
Old Jul 27, 2012 | 03:28 AM
W211
Thank You for reply - Will try this afternoon - and let know what is the result
Old Aug 2, 2012 | 11:52 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
needs a re-gas for the Air con and then the code needs to be reset using STAR. I had this a few months back, been fine since.
Old Aug 2, 2012 | 05:28 PM
W211
GAS
Hi. Thanks for the reply - it was not the gas, system has had more pressure than required (checked by professional) so I borrowed "Launch" computer from my friend, reseted error codes and it is back to "normal" - normal means it is blowing cold air only on 1 zone, and the REST BUTTON on th econtrol panel doesnt work - so now I suspect it is the AC control panel. Please does anybody have instruction how to remove the panel please? thought that one of the air FLAPS inside the console is gone but computer shows normal values for left and right - the only thing computer says that COMMUNICATION WITH ECU NOT NORMAL for both zones flaps motors
Old Aug 2, 2012 | 09:39 PM
06e320cdi's Avatar
2008 ML320CDI
Just as a point of reference, too much R134 can be as bad as too little. It might be worth subscribing to www.alldatadiy.com, its a cheap subscription that covers some of the WIS info.
Old Aug 3, 2012 | 02:24 AM
W211
Guy from Air Con company said the same so he just made the pressure correct.
Old Aug 3, 2012 | 02:34 AM
W211
Goingto change AC control module next couple of days, bought one of ebay, now just looking for the manual "MB - A/C for dummies" :-) - Will let you know how it goes
Old Aug 5, 2012 | 07:38 AM
W211
A/C Control Panel Panel Removal ,dashboard with mesh version 2004 W211
Here is hot to remove A/C control panel W211 2004 - E200 with the mesh version on dashboard
However - bought new AC module and problem still exists - next step is to get into the "freezer" blower flaps
Attached Thumbnails A/C red colour blinking button W211 E200 CDI- 2004-w211_mercedes_dashboard_mesh_removal_ac_panel_slawek_sawicki_1.jpg   A/C red colour blinking button W211 E200 CDI- 2004-w211_mercedes_dashboard_mesh_removal_ac_panel_slawek_sawicki_2.jpg   A/C red colour blinking button W211 E200 CDI- 2004-w211_mercedes_dashboard_mesh_removal_ac_panel_slawek_sawicki_3.jpg   A/C red colour blinking button W211 E200 CDI- 2004-w211_mercedes_dashboard_mesh_removal_ac_panel_slawek_sawicki_4.jpg
Old Feb 12, 2014 | 01:10 PM
TheFridge's Avatar
E200
Hi did you get to the bottom of this ?
I have just got my car back from mechanic and the ac off button is illlimunated.
When I press it it just flashes a few times and goes back to being off.
Annoying the hell outta me, no power in the heater
Old Feb 13, 2014 | 03:35 AM
W211
Mercedes W211 AirCon light blinking
YES - You can't believe what was that. In UK we had mobile aircon specialist
who has connected his "equipment" and said that there is too much pressure in air con system - so we were thinking that we have full system. After 2 attempts of resetting computer the light was still back. We went to another aircon specialist in POland and he said that the idiot in UK almost fuc... our aircon system because in Mercedes there is some special way how do u measure pressure - at the first sight u can see that you have full pressure but there are 2 zones and you have to measure them separately - so he did check only 1 zone - the 2nd zone was empty and computer is preventing the whole thing against collapse by switching it off. He said if you force and reset computer 2 -3 times it will allow the system to work on low or no pressure your pump can be gone.
We have filled up the second zone and the system is on and working.
Old Feb 13, 2014 | 10:11 AM
'71 Pinto
First step with AC OFF light illuminated is to check refrigerant if fine, attempt reset as previously suggested if this fails then SDS test for definitive diagnose.
Old Feb 13, 2014 | 02:35 PM
TheFridge's Avatar
E200
When you say reset do you mean disconnect the battery ?
Old Feb 13, 2014 | 03:59 PM
'71 Pinto
Yes - post 2 above.
Old Jul 29, 2015 | 05:37 PM
michalk's Avatar
2004 E55 AMG
Originally Posted by Plutoe
Quite possibly you may be confused---up to 31 05 05 when compresson on--- LED is off, however as of 01 06 05 LED is on------- when compressor is on!
The potentially bad news is that with the W211 the AC control units can't be self diagnosed like the previous W210-----that means a trip to the dealer for a fix and or an indy with factory diagnostics or overlook the problem and live with it!!
I have a 2004 E55 AMG. I have tried all of the button combinations to get into the error codes. I can get the sensor readings. Does your comment above mean that the W211 doesn't provide the A/C error codes?
Old Jul 31, 2015 | 05:51 PM
michalk's Avatar
2004 E55 AMG
Piutoe,
This is the second time I've seen this statement. I've been trying to pull the error codes off my 2004 E55 AMG. Are you saying there is no way to pull these codes except for SDS?
Old Jul 10, 2018 | 07:38 PM
Johnnyw211's Avatar
W211 220cdi
How did you recharge 2nd zone?
Old Jul 19, 2021 | 06:47 PM
prodigy81's Avatar
Mercedes E200
Exclamation
Hi there, did you manage t get your's fixed. I have the exact same problem. My model/verion only has the AC/off button nd its permanently on, when you press it flashes then goes back to being solid.
If I reset it (remove battery leads in boot) is it a pain to resync everything back up.
