E-Class (W211) 2003-2009
Car wash damaging transmission?
Old Oct 12, 2012 | 06:24 PM
Haight2's Avatar
E550
My 2007 drove into a car wash today, just fine. When it came out, it wouldn't move. It shifts into drive and will shift through gears...(sitting still, no speedo registering)
Acts like a broken output shaft..? If it has one. Any ideas? Anything the car wash could have caused?
Old Oct 12, 2012 | 07:51 PM
vettdvr's Avatar
03 E500 and Corvette
speed sensor that controls spedo? You didn't say if it was running or not. If the engine is not running CPS.
Old Oct 12, 2012 | 09:53 PM
Haight2's Avatar
E550
Starts and runs. Won't move but acts just like a drive shaft was removed. (Except no speedo) goes in gear and shifts through them. When you put it back in park, the paw grinds then engages. When sitting in park, car will roll.
Is there an output gear or shaft at back of trans that could shear?
Old Oct 12, 2012 | 10:32 PM
benzmodz's Avatar
W203 slightly modified
Strange. You may have water in the connector that goes into the transmission.
Old Oct 12, 2012 | 10:40 PM
Haight2's Avatar
E550
Is there a "rear" clutch that can electronically disengage though. Very weird that you can hear it engage in drive, and shift through all the gears while sitting still....
I'm not familliar at all with the trans...
Old Oct 12, 2012 | 11:10 PM
benzmodz's Avatar
The torque converter is disengaged and the gears are just moving without resistances.
The torque converter is attached to the wiring harness between the engine harness (7 speed) or the transmission module (5 speed).
