W211 E350 Power steering problem
One with the "speed sensitive" assistance and one without. Mine being the latter.
I have bled the system numerous times and literally spent 30 minutes going lock to lock, even ended up changing the entire rack.
When the car is cold, the steering is really very light, as it should be, but when warmed up, it's next to impossible to quickly turn the wheel lock to lock...it just behaves like there is NO power assistance. This is an absolute nightmare whilst parking or trying to maneuver.
Sounds like the pump is bad, did you refill with the proper power steering fluid?
When the system is warm check the temp of the steering fluid with your finger if you do not have a laser thermometer gun. Also look into the top of the reservoir of the power steering while turning wheels to see if there is oil movement through the tank.
Ask a MB tech if there is any reset on the system after having work done on the car?
A question may save you some diagnostic time.
The power steering fluid is Pentosin CHF11S which is available even at NAPA.
Please enlighten me as to what is so special about pouring the PS fluid down the reservoir tank and turning the wheel from left to right. You do that, the PS pump noise goes away, you look at the temperature, fill it up to the correct temperature level, that's it. How do I know this? I've drained the PS fluid 3 times already on this car over the past 2 years and am yet to take it to a shop for anything "proper".
"Factory bleeding specs"? What in the world is that?
