E-Class (W211) 2003-2009
Crafty Built 211
Old Nov 5, 2012 | 11:59 PM
Craftysince86's Avatar
W211
Arrow Crafty Built 211
so the time has finally come to assemble my car
i have never done a build thread before but it seems that it's pretty difficult to find info about these cars so i figured whatever i can contribute to the community is a plus
i have a some what stock 2003 e320, here all i have done is limo tint with 35% on windshield and it is on lowering springs, i believe they are eibach
pretty much a full cosmetic build, it's a base so i didn't really see the point of any real performance based mods
up to now i have kept to only interior mods, i did most a while ago so i won't go into too much detail but i did all the work myself so if you have any questions i will try and answer the best i can
a while back i did an arm rest swap to the roll top
if your changing from the clam shell just make sure that you get the piece around the shifter as they are different shapes where it meets the arm rest
also added a "euro" nav, there was a lot of questions about the compatibility that was pretty difficult to answer but as long as you have the HK sound it is all plug and play
had machack setup the video in motion great guy if you ever need any help of that sort
also had a JL 10 W7 with JL 500/1 amp, this was just something i took to an audio because i did not know how to convert the fiber optics portion. i also added the trunk drawer you can catch of glimpse of it in this pic.
only exterior mod i have done is E63 tail lights which are also plug n play, unfortunately i don't have pictures at the moment but i will update with some
so now that you are all caught up, i have complete aero for this car, full body coil overs, wheels, diffusers and lips, exhaust, bi xenon headlights with xenon fogs as well, etc. i wanted to keep it simple so i pretty much just went all oem
this car build should be done 2-3 weeks from today, feel free to quote me! wheels and tires came in today so that will be the first thing i do early in tomorrow morning
some teasers of things to come, enjoy
Old Nov 6, 2012 | 11:21 AM
09W211's Avatar
2009 W211 E350 AMG Sport PKG
varrstoens? esm? bbs? tire sizes & specs? can't wait to see it dumped!
Old Nov 6, 2012 | 11:40 AM
W211
They are varrstoens 19x9.5 +20 and 19x11 +25
Running 225/35 and 245/35
I really wanted LM's but I was hesitant about feeding them to the wolves lol this build is for the wife, that and my buddy owns a shop so I paid straight cost on these wheels
Just got back from mounting the tires the rear got a nice stretch the front... Not so much but it'll do for now
Old Nov 6, 2012 | 12:09 PM
09W211's Avatar
holy ****...you stretched 245s on an 11??? damn and i was skeptical about putting 255s on my 11. you helped me so much by posting these pictures up. looks like i'll be running 255's on my 11! did you get a camber kit?
Old Nov 6, 2012 | 12:16 PM
W211
I did not, I'm hoping the natural camber will sink them in enough for to avoid any body work, I test fit at stock height and I should be ok but I am just going to run what negative camber I get and zero in the toe
I wish I would have run 215's on the front but my friends were trying to talk me into 235 so I was back n forth on 235 and 245 but I'm happy with the stretch I got
If you ever need to reference tire stretch there is a website that has various wheel widths and tire sizes on them... I'll find the site and post it
tyrestretch.com
Old Nov 6, 2012 | 12:27 PM
09W211's Avatar
Yeah..tyrestretch.com or something like that. just couldn't find any 20x11 stretched on 255. Your's aren't 20's but I can get a general idea now
Old Nov 6, 2012 | 12:33 PM
W211
Yea 245 is a pretty common size for 11's if your trying to stretch, are you trying to stretch? Some tire brands also differ even if they are the same size
I'm running nankang ns-II
Old Nov 6, 2012 | 12:36 PM
09W211's Avatar
Yeah, I have to stretch in order to fit my 11's, but 245 is just too much for me. I'm running Falken FK452 (discontinued) 275's on my rears right now but they rub on dips pretty badly. But not sure which brand to go with if I run 255's..
Old Nov 6, 2012 | 12:41 PM
W211
Oh yea if you can fit 275 rubbing you should be good with 255
Old Nov 6, 2012 | 12:58 PM
09W211's Avatar
Here's my 275
Old Nov 6, 2012 | 01:05 PM
W211
Dang! Yea I wouldn't go 245 either you have a little bit if stretch already
Old Nov 6, 2012 | 02:20 PM
W211
more to come...
Old Nov 6, 2012 | 02:23 PM
09W211's Avatar
Looks like I'm gonna be run 245's in the back. Throwing them on tonight!
Let me know how the KSports feel after you throw them on, and how you're able to adjust the height on the rears without dropping the whole subframe.
Old Nov 6, 2012 | 03:26 PM
W211
why would you have to drop the rear subframe to adjust the collars?
Old Nov 6, 2012 | 04:09 PM
09W211's Avatar
the whole spring assembly rotates when i try to adjust the collar. and there's not much room available for me to turn the collar with the limited space and the shock in the way...i'm a noob :/
Old Nov 6, 2012 | 04:18 PM
W211
oh no i'm on coil overs not air, so my strut and spring are separate in the rear. i will be able to adjust the height just by pulling the wheels off and turning the collar down.
the fronts are one piece so for those the bottom mount does adjust up and down and i will probably have to pull them out to adjust them
Old Nov 6, 2012 | 04:29 PM
09W211's Avatar
I'm not on air either. I have the same setup, but for some reason when i try to adjust the collar to lower the rears, the whole body turns so nothing gets adjusted...does that make sense?
Old Nov 6, 2012 | 04:32 PM
W211
what suspension are you on? and did you drop the rear sub frame when you installed the suspension?
Old Nov 6, 2012 | 04:55 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
245 on an 11" wheel? Wow, there goes what little handling you had
Old Nov 6, 2012 | 05:15 PM
W211
car is just a daily driver, so besides arming myself with a tire pressure gauge not sure i will be losing out on anything
Old Nov 7, 2012 | 11:31 AM
Blown_V8s's Avatar
C5 LS6 and CLS55
This is horrible! and you're letting your wife drive it too
Spend the extra cash and get some wider tires that actually fit the rim!
The first hard turn you hit with that botched tire setup, it's going to slip off the rim.
Old Nov 7, 2012 | 12:32 PM
W211
my friend daily drive a ls430 with 20x10.5 on 235... tell me more how my tires are gonna fall off of my wheels
tire size was a conscious choice not trying to save money choice
Old Nov 7, 2012 | 12:38 PM
AKnight55's Avatar
Old Nov 7, 2012 | 12:53 PM
09W211's Avatar
moar pics of the VIP celsior please!
Old Nov 7, 2012 | 12:55 PM
W211
a bit exaggerated... but i guess its a good thing this isn't any of your cars
find it funny that as soon as someone wants to build something a little different these boards are just all over their dick
you should all be car enthusiasts and appreciate peoples builds for what they are not what you like, and appreciate any work done well.. but then again what do i know
