E-Class (W211) 2003-2009
Simple starting problem E500 2005
Old Nov 23, 2012 | 07:36 AM
artbissell's Avatar
2005 e500 4matic
Strong starter turnover. No fuel. Inject a little starter fluid and briefly fires. checked fuel pump relay in trunk fuse box by shorting wire in socket contacts. Instant start and $15. relay cured at 91,000 miles. I assume one of 2 fuel pumps would run engine if one failed? That fuel pumps good for more than 100k miles?
This problem not exactly identified by MBZ fault analyzer.
Old Nov 24, 2012 | 09:43 AM
vettdvr's Avatar
03 E500 and Corvette
Good problem solving. Can you post pic of location or part number?
Old Nov 24, 2012 | 10:32 AM
artbissell's Avatar
2005 e500 4matic
fuel pump relay e500.
At bottom of fuses and other relays behind little vertical door on left side of trunk interior. was not given part no.It is little black block with 4 terminals, 2 inline ones are contacts and will read open circuit good or bad.
