E-Class (W211) 2003-2009
Best technique to remove taillight blackout paint
Old Feb 21, 2013 | 12:26 PM
mohd3333's Avatar
E-240 2004
Cool Best technique to remove taillight blackout paint
Am bored from taking tickets for my blackout tail lights
So i had decided to remove the paint myself to finish this story
I found many ways in internet of removing this paint starting from acetone to diesel to sand paper to heating ......etc
I dunno which one is the right as i dont wanna scratch the lights or end having some foggy glass , so i hope someone here can give me a technique which used by him with no bad side effects
Old Feb 21, 2013 | 02:07 PM
AMGAffalterbach's Avatar
2014 BMW M235i
I've heard people trying to use laquer thinner on different sprays with bad results, but I have found (not through personal experience) that acetone and then polishing them out with a buffing wheel should work. Did you use VHT Nightshades?
Sanding/stripping even if you get foggy glass followed by high speed buffing probably works the best. Or you could find someone on the forum that wants to swap with you, just do a direct swap. I'm sure someone wants a set of tinted ones - that'd be the cheapest solution.
Old Feb 22, 2013 | 05:23 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Buy a 3M Headlight cleaning/resto kit. Hit it with that. The 500 is a little soft for paint but should knock it down nicely. Follow the kits instructions and they will look new when done.
FYI, add Buffing and polishing compound in at the end to really clean up the housing. And take your time.
Old Feb 22, 2013 | 03:16 PM
2014 BMW M235i
I've heard of people using toothpaste as a buffing compound in this application and it working perfectly hahaha
Old Feb 23, 2013 | 10:33 AM
Vander's Avatar
2002 E55 AMG, 06 C55 AMG, 72 350SL
Swapping with someone on here is a creative idea.
Old Feb 23, 2013 | 11:42 PM
2014 BMW M235i
thanks.
Old Feb 28, 2013 | 12:29 AM
mohd3333's Avatar
E-240 2004
Thanks for this tip , i will do an order for the 3M Headlight cleaning/resto kit
What about Gasoline Octane 92 , does it work ? cause i saw some vids at youtube applying gasoline and rub the light by coat even without sanding the same , anybody have a try with it ? or is it safe as i dont wanna ruin my lights
By the way , how can i take my lights out of the vehcile , can anyone gimme some tips to do so
Old Feb 28, 2013 | 12:50 AM
2014 BMW M235i
Try the restoration kit. Light abrasion with a purpose-built product is better than a strong chemical like gasoline, as plastic on car lights is easy to buff out. If you're worried about cost, just use toothpaste. It's the same consistency as most polish. Restored by headlights with a kit though, and they look brand new with a little elbow grease.
Old Feb 28, 2013 | 01:31 AM
mohd3333's Avatar
E-240 2004
thnx man , i will go ahead with the kit to stay on the safe side
But do u have any odea how to take the lights out , as i dont wanna damage surrounding area by doing something in a wrong way
Old Feb 28, 2013 | 12:41 PM
gregw's Avatar
2006 E-350
Your probably going to think I'm crazy for suggesting this BUT...
The best thing I have found for removing paint from plastic is dot3 brake fluid. I've used it to remove paint from plastic interior panels and lexan RC Car bodies. It eats the paint off without harming the plastic at all.
There is a ton of information about it on youtube and google if you want to see it in action. Just hate to see you haze the tail lights with anything abrasive.
Old Feb 28, 2013 | 01:39 PM
forcefed4door's Avatar
05 E55, 06 Audi S4
Nail polish remover
Old Feb 28, 2013 | 02:09 PM
QFT. This works...VERY well. Not sure why I didn't remember it when I gave my suggestion.
Old Feb 28, 2013 | 02:14 PM
2014 BMW M235i
>pick one
>try it
>let us know how it went
