E-Class (W211) 2003-2009
BRAKE MESSAGE RESET
Old Mar 7, 2013 | 12:43 PM
ChuckinTucson's Avatar
2012 S63, 2013 E350 Bluetec
BRAKE MESSAGE RESET
Have a 2006 E320CDI. Replaced the rear brake pads, but the message on the dash still says that brakes needs replacing. Does anyone know how to get rid of this message?
Old Mar 7, 2013 | 04:39 PM
vettdvr's Avatar
03 E500 and Corvette
Check your brake fluid level.
Old Mar 7, 2013 | 09:27 PM
Yes, the car does have Sensotronic system.
Old Mar 8, 2013 | 01:58 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Originally Posted by Plutoe
I believe that is the issue. You must have had someone change the pads that did realize that a step in the pad install on a Sensotronic brake system requires the use of the DAS Xentry diagnostic software to instruct the system that there are new pads.
Now you have to go back to "seattle sam" and ask him to complete the install of the brakes. If "seattle sam" says Da-----then it's off to the dealer!!
You give excellent technical advice Plutoe but your ways of saying things confuse me sometimes
Old Mar 9, 2013 | 01:23 PM
Just got back from the dealership. The person who replaced the brake pads evidently broke the sensor. $100 later, all fixed at the dealership.
Old Mar 11, 2013 | 09:03 AM
vettdvr's Avatar
The sensor is basically just a loop of wire in a plastic housing cost $4.50. I would guess the $95.50 was labor.
IF they replaced the pads why and failed or broke the sensor , plug or failed to plug in why did you have to pay the $100 for their error?
Old Mar 11, 2013 | 04:52 PM
Tschuss_Bill's Avatar
2005 E320 CDI
Not sure I agree with the requirement to go to the dealer to reset for pad change. I did not have to do that. It was the sensor.
