Replaced Main Battery Today
You will have to reset the ESP system afterwards by turning the steering wheel from lock to lock with the engine on in park, and then sync the windows by running them all the way down, then all the way up, continue holding switch in the up position for one second after each window closes. That will restore the one touch up/down feature. You will need to sync the sunroof by pushing up to tilt the rear edge of the glass up, then continue holding switch in the up position for one second. Then reset your clock and you are all set.
Im just checking to see how that battery is holding up for you? Ive been eyeing that one to replace my main battery in my 2003 E500.. I was having the same issues as you were, except to add that the non-mercedes dealer I purchased the car from put a regular lead acid battery in mine (autozones 49H8) and needless to say ive been having dead battery issues along with having my consumables cut off..
But one more question for you foreyes since we have the same car, How in the world do you check voltage through or on the display? Ive seen put the ignition on 1 then hit the trip odometer button 3 times, but this does nothing for me.. I know it wouldnt be the most accurate way to check it but it would be just something for general reference it would be an idea of my battery status..
BTW, I can't get mine to display oil status. I can get it to display voltage when I press trip odo reset three times and MPH is displayed. But when I have temp displayed and hit reset three times, nothing.
Oil level, at least in my car, is via menu, not reset button presses.
