Airmatic suspension question
I am looking for some help in finding a solution.
My 211, if it sits for 4 days the rear goes down about 1.5" equally on both sides. It doesn't go down if it sits only one or two days.
I am baffled by the fact that only the rear goes down and not the front. I have analyzed the pneumatic schematic and it appears that there are only individual valves inside each spring and a general valve at the pump.
However in the system there is enough pressure, when I open the door (I wake up the system) the rear is being pushed up by what is stored in the reservoir only, the pump doesn't turn on.
It appears that I have some small leaks equally in the rear springs only.
Is there anybody else that has been through this?
I find it surprising that both rear springs have small leaks at the same time. If there was a leak somewhere else like the lines or the rear tee then the front springs should have been down too and the reservoir empty. Or maybe there is a valve separating the rear from the front and it's not shown on the schematic?
If the rear air splitter would have a small ball and spring in it as a check valve it would explain all. N fortunately it doesn't show on the schematic.
I have changed EVERY POSSIBLE THING on the airmatic on my e500 and the car still sits on the ground sometimes and goes down unevenly. I have spent over $6,000.00 in repairs for this damn car. I've changed all four airmatic shocks, all four standard shocks, the airmatic pump. That is the WHOLE suspension. The only thing left is the block valve and now i'm thinking that the block valve might have been the issue from the start. So before you make any major repairs, change the block valve and check for leaks. Could save you major $$$ in repairs.
GOOD LUCK! I hope you don't have my luck!
