E-Class (W211) 2003-2009
2009 E350 Navagation questions
Old Aug 13, 2013 | 02:14 PM
StanVoronin's Avatar
2005 e320 CDI
hey guy im having a e350 shipped with carmax, in about a week it will come in.
going through the features "GPS" isnt listed
does the 09 e350 not come with street navigation?
if not what do i need to do to get GPS?
also will its pair and stream music off my iphone5?
if not is there a AUX port?
i paid $650 to have it transferred, no commitment to buy
id rather lose the 650 and get a MB with navigation and iphone bluetooth streaming
i noticed in the 09 the navagtion is different from a 08
is it touch screen?
Old Aug 13, 2013 | 04:05 PM
PortAxePlayer1's Avatar
'97 E200, '06 E350 & '23 E350
I'm not sure if the '09 came with GPS standard, but i don't think so.
However it did come with the revamped COMAND which is much better than 08 and less model years. It's not touch screen, Mercedes doesn't offer any touch-based navigations systems.
It does have AUX.
This COMAND does have Bluetooth built-in and i'm pretty sure it streams audio off your phone.
If you have the VIN i can look it up for you and give you the detailed options before you buy it.
Old Aug 13, 2013 | 04:18 PM
2005 e320 CDI
It does have AUX.
id really appreciate it
vin# WDBUF56XX9B436971
Old Aug 13, 2013 | 04:51 PM
All right then, datacard shows: CODE 528: COMAND DVD PLUS (Without Navigation) so i guess there's your answer.
I'll attach the pdf in a few minutes, i still haven't got a pdf program in my new pc yet.
Old Aug 13, 2013 | 05:19 PM
Datacard as promised:
File Type: pdf
Old Aug 15, 2013 | 11:39 AM
2005 e320 CDI
perfect! I appreciate that
is it possible to add a rear view camera?
also can I buy a headunit with navi option? would it be plug and play?
Old Aug 16, 2013 | 10:52 AM
Barry45RPM's Avatar
2015 ML 350
What is "LOW COST" teleaid USA what else would it do if it were "high Cost"?
Old Aug 16, 2013 | 11:35 AM
I'm not sure but from my readings i think you can. However this involves A LOT of labor. I personally would just leave it..
Since it's NTG2.5 then the maps load directly from a built-in hdd so no need for a disc-> no need for Navigation DVD Drive in the back. However i am sure you would need the antenna and some other stuff.
Here’s a website that may answer all the questions you have concerning COMAND and some retrofits.
http://www.commandonline.co.uk/Mercedes-Retrofits/
Old Aug 16, 2013 | 11:36 AM
It's misleading, actually the low cost teleaid is the digital version of the Initial tele-aid which was analog only when it was first introduced. There's no higher cost one.
Old Aug 16, 2013 | 05:00 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
It does have AUX.
All US-Spec W211s from 2007-2009 came with P1 Package standard, which included navigation. The only way it wouldn't have that is if the Original Owner opted out for some stupid reason.
Old Aug 16, 2013 | 05:18 PM
On the datacard i pulled it was specified that the COMAND he has comes without Navigation. Now that rings a bell, i remember P1 having Heated Seats, H/K Sound System and rear sunshade as well as navigation.
Maybe the '09 was different because of the new COMAND ?
Old Aug 18, 2013 | 06:33 PM
rsmith7's Avatar
Veteran: Navy
2009 E350 Arctic White AMG Sport package W/ P2 option, 2002 C230 kompressor Coupe
Although the 2009 has bluetooth onboard, you are unable to stream music. This is only used for the phone. If you want to stream music, one option is to purchase a Mercedes Media Interface Plus (MIP). This plugs in the glove box port. However, as an owner of a MIP I would not waste my money. This device creates headaches when using the phone.
Old Aug 19, 2013 | 11:47 AM
velocipedist's Avatar
2009 e350
Data sheet on one I am looking at has option 512 - Comand APS with DVD changer. Does that mean it comes with Nav?
Old Oct 22, 2013 | 11:16 AM
2005 e320 CDI
hey guys my car does not have NAVI
my question is it does not show HD Radio Either
any way to enable it?
Old Oct 25, 2013 | 02:06 PM
starbrite's Avatar
2004 E320
So, I guess that means you bought it? No, no way to enable HD radio.
