gas fumes in the garage
Anyway, every three hours or so I would smell the garage and the gas fumes were unbearable. Each time I would air it out with a fan and return to find the fumes just as bad.
I have read many threads on the fuel sending unit in the car under the rear seat cushion cracking and giving off a gas odor "IN" the car. However, this is coming from somewhere "outside" the car.
I spoke with my MB SA and he said there was a known issue with something involving the fuel delivery around the gas tank. He said it can occur when the car has been refueled to its maximum capacity just like the issue with the fuel sending unit under the rear seat cushion.
I have the ELW until May of 2014, so no worries it will be covered. SA said I should bring in the car when the fuel is very low because if it is this issue he described, they have to empty the fuel and discard it. Then replace the fuel tank itself. Sounds expensive, looks like my ELW may pay off.
Just wanted to run this by this forum to see if anyone else has come across this issue????
And...do you think I should check the fuel sending unit under the sear cushion and check for the puddles of fuel that can form if something is amiss, and if so have them replace that too?
thanks.
Yes I have driven it, maybe 50 miles or so. No issues, at least not the ones you described you had. Have not put it back in the garage to see if the gas smell still emits. I do know for sure that there is absolutely no gas smell "in" the car. It may still be giving off gas fumes, but outdoors it is almost impossible to detect.
I do know I get terrible gas mileage, 14 city/21 hwy at best. Maybe this suckers been leaking all along.
Since I'm under warranty I'm not really that worried. If I was without the warranty I'd do a lot more testing and poking around before taking it in to MB. But, I'll just take it in and get as many things replaced with new ones as possible.
I paid $3,100 for the 3 year/75,000 mile MB ELW (extended limited warranty) and 2 years and 3 months into it I have not had any claims.
I was kind of hoping some issue would come up and justify this purchase. Sounds weird, like hoping you have a flood to justify your flood insurance. I guess what I means is, I was hoping one of the many known issues these cars have would rear it's ugly head so I could have it remedied under the ELW and scratch it off the list of future problems when out of warranty.
If you have warranty coverage, by all means get it fixed. If they are going to replace the tank, they will surely replace the sending unit seals as well, as those units come right out the top of the tank.
Had to replace crankcase vent valve, cam housing plug 30m and 65
After, gas oder was gone.
