Stuck brake caliper piston question...
$1,600 estimate to replace both the front calipers and rotors.
My questions:
1. Can a stuck piston be repaired/rebuilt?
2. If not, do you have to replace both front calipers, or can you just replace the one?
My questions:
1. Can a stuck piston be repaired/rebuilt? Yes but not worth the time or effort replace it.
2. If not, do you have to replace both front calipers, or can you just replace the one? You can just replace one. IF you drove in heavy salt or other chemicals that may have eaten the seals on the caliper you might consider replacing two but not manditor.
Over $1000 to do labor? WAY WAY HIGH IMO.
MB E-Class has dual piston calipers so this would probably not apply if only one of them was hanging up...
