E-Class (W211) 2003-2009
e500 would not start.
Old Oct 16, 2013 | 10:11 PM
sl5dave's Avatar
96 SL 500 05 E 500
Upon returning to car from restaurant, car would crank but not start. After 30 minutes it fired up and ran fine. It seemed as though the fuel pump was not engaged until my last failed attempt at starting. As I turned the key back after the last failed attempt it sounded like the pump engaged. I then successfully started it. Any imput will be greatly appreciated. Thanks in advance!
Old Oct 16, 2013 | 11:45 PM
desired_speeds's Avatar
2007 SL55 AMG
crank position sensor
Old Oct 16, 2013 | 11:48 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
^ ditto, but to be sure, have codes checked at Mercedes indie shop. The CPS is located at top rear of engine. Took me about 15 minutes to remove and install a new one in my E500.
Old Oct 17, 2013 | 01:14 AM
NBDT's Avatar
2004 E500 (W211)
Yes, CPS. I had the same issue as the others this past summer.
