Torque arm bushing 2113332914 or 2113331114?
There was a TSB calling for solid rubber bushings with PN 2113331114.
Which is correct?
If you receive customer reports of a steering wheel twitch during slow speed brake applications, replace the hydro-mount or partially hollow rubber style bushings (which ever equipped) with solid rubber bushings. The steering wheel twitch condition can usually be maximized during slow speed repetitive brake applications, such as those encountered during stop-and-go traffic or toll booth scenarios. The originally equipped torque strut bushings (hydro-mount or partially hollow rubber) can deform under braking applications, resulting in left or right steering wheel rotation. The solid rubber bushings have an increased resilience towards deforming during suspension loading.
Solid rubber 2113331114 MSRP $37.50 to comparison shop, http://www.autohausaz.com/search/pro...tm_campaign=cj $20.44
Is this part (2113331114) is in this unit 2113304411 Control Arm (Thrust Arm) ?
My indy mechanic state that the bushing on my left control arm is cracked and needs to be replace.
