E-Class (W211) 2003-2009
Old Jun 17, 2015, 03:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Engine Guides
Print Wikipost
Please help, Battery Dying Issue
Old Nov 15, 2013 | 02:57 PM
TigerShark333's Avatar
E500 Sport
I did a search each situation seemed to be a little different form mine. So I figured I would make my own thread.
I usually have my lights on Auto. About a week ago I left my lights on and it killed my battery.
I jump started the car, drove fine but it had this written on the speedo. "Battery Protection Conven. Functions Temporarily Unavailable."
It would come and go depends on how much I drive. Two days ago I had to jump start my car in the morning.
Then that night again dead battery. I went to AutoZone the guys ran a test on my battery in the trunk said it was fine just a little low and ran test on alternator said it was fine. Just that battery needs to be charged.
So I went for a long drive. Next morning car started fine. I worked from home and then this morning again completely dead.
Please help if you have any experience in this. Battery seems to be fine, alternator is fine, it takes the charge it just drains if I leave it sitting.
It's a 2003 E500.
Old Nov 15, 2013 | 03:27 PM
E500 Sport
I'm thinking it could also be the battery control module but why would it have problems now when it was working fine before. Did the jump start fry it?
Old Nov 15, 2013 | 06:03 PM
starbrite's Avatar
2004 E320
Did you jump start it from another car? If so, it should have been off when connecting the cables and start attempt, to avoid any spikes. These cars do have sensitive electronics.
It's always best to charge the battery, if possible, rather than jump start.
Old Nov 16, 2013 | 07:32 PM
vettdvr's Avatar
03 E500 and Corvette
No it would not fry. But it does have a mechanical relay inside and the points will burn out this will cause dead battery overnight.
MB 2115408645
Old Nov 16, 2013 | 08:10 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Just how old is your battery? If it over 5 years then just replace it.
Old Nov 18, 2013 | 01:01 PM
E500 Sport
Hey all. Good news. I took it to Autozone. They charged both batteries for me for free. Put them back in and day 3 everything is working fine. Haven't seen the errors yet.
I think after jump starting it the battery would never fully charge. Just have to get them fully charged.
Old Nov 18, 2013 | 01:56 PM
phalen302's Avatar
14 S8, 07 E63 Designo, on order 14 G63
BCM might be going bad. The function of the BCM is to control the battery drain when not in operation. MB has updated this part several times in last 4 years.
After couple of days if your battery drains dramatically, I would get the BCM checked out. Other culprit might be alternator or battery itself. But I have rarely seen alternator going bad.
Old Nov 18, 2013 | 02:45 PM
Critter's Avatar
How old is the battery? batteries?
Old Nov 19, 2013 | 01:08 AM
navreet's Avatar
2001 SLK320
On my 2010 GLK350, I have the same problem. I have the Power Jump Pack which starts the car right away, but after charging the battery overnight with a charger, the battery shows full charge. After a few starts during the day, it dies again. It gas 46200 miles.
Old Nov 19, 2013 | 11:14 AM
Critter's Avatar
navreet, check voltage before starting car should be around 12 volts after starting the reading should be 14.2 approximately, this will tell you the charging system is working fine. Your battery if run down previously from sitting or leaving the lights on. Some parasitic drain when the car is shutoff is also plausible. Have battery load tested if you are seeing 14+ volts when car is running. May be time for a battery as these cars can be power hogs. Good Luck!
