Sat radio....
Also does the E500 have a jack in the dash/glovebox? A friend of mine has the SL55 and he says he has a jack to connect other audio devices....
Anyone?
Canthe phone option be installed as an aftermarket part, or only from factory? I like the option, but don't want to pay $1500.00
thanks,
Madd
There is an AUX jack somewhere, and you see an option when you press the Audio button for AUX, and a few people have done it.
Don't know when Sat radio is expected, but I heard sometime in the first quarter next year. I'm thinking it should be a pretty easy install, and the actual module should run maybe about $500??? Don't know anything yet.
right now the only vehicle that i own that has it is my GMC p/u. it has XM. really a nice feature. i think the future of radio stations is jeopardy with this new technology. it makes driving much more enjoyable.
Actually, all Honda's and Acura's offer XM standard for 2004, with the first 3 months free, afterwards it's $9.99 a month.
The funny thing, is the MB E-class with navigation is already prewired for sat. radio. Now what does that mean? I called a few dealers and they said they had no idea, one said to expect it soon. I wish people had answers!
I was also looking into getting an IPOD, they have a cool feature, with a $30.00 attachement, it broadcasts a signal to FM radio so you can play all the songs! What do you guys think?
MADD
If you'd like any info, I'd be happy to provide it.
Sirius has significantly fewer customers than XM, and XM has better hardware from what I've seen. I do not see how the Sirius value is greater than XM given the Sirius price is higher.
On Command II, you preset the frequency which is visible on the screen. You cannot depress the SAT button for XM.
XM has 2 sats up in space, but they also use tons of repeaters on the ground level. Supposedly, the XM signal strength can vary quite a bit leading to differences in perceived volume levels.
I didn't realize that Sirius was in such $$$ trouble...
Everyone I talk to says XM's the way to go.
Your sat antennas are mounted inside the car? Up under the rear deck in the trunk?
No probs with reception?
TIA.
My first XM unit was a Sony which I used on a Volvo. That unit's antenna sat on the roof and looked like a smallish shark fin. I haven't perceived any significant differences between the reception I used to get with the Sony unit and what I get now.
I contacted irius again last night, bacially we need to get an ESN number from the dealer, oncethey give it to us for our car, they'll be able to connect if the car is already prewired.
If you look at the manual for Comand, they show you screen shots for Sat. radio. It displays the channel under the speedo, and has the artist, album, and song displayed on the screen.
I have a couple of questions to people that already installed it....
1. With XM or Sirrus connected externally with antenna inside truck, so you have song info displayed, on command?
2. Are you using the aux. jack for sat. radio?
3. do you need a seperate antenna or can you use the one located on the back windshield? Looks like sat antenna.
Marc
I contacted Sirius again last night, basicially we need to get an ESN number from the dealer. Once they give it to us for our car, they'll be able to connect if the car is already prewired. It's very frustrating that MB has not released any info!
3. Do you need a seperate antenna or can you use the one located on the back windshield? Looks like sat antenna.
Marc
I just called MB...they said sat. radio will be available in January 2004. It's going to cost 12 per month, or you can get 1 years agreement with 1month free. They already have seen the presentations from Sirius. Installation will require an antenna mounted in the truck and some wiring. Pricing for installation is up to dealer.
With my Alpine XM unit, the name of the artist and the song are displayed on the XM unit itself, not on the Mercedes. The quanitity of displayed information depends somewhat on the unit in the car; XM apparently sends out more info than some units display. Even if you have COMAND, your car will not be able to put this info on its own display unless you are using the Sirius system.
Since I do not have an AUX input, I don't have that option. I had to use an FM modulator, which broadcasts into the car's FM antenna. If you have an AUX input, it is possible that you could use that, which would theoretically provide better sound; I believe that some of the XM units can use an auxiliary input, and some cannot.
You need to use a separate XM antenna. As I indicated in my prior post, that is not a big deal.
IT'S OFFICAL!!!!!
http://www.sirius.com/servlet/Conten...=1019257316818
I would be cautious about spending alot of money on the radio hardware and installation, I really do believe Sirius will not make it. Too bad MB didn't go with XM.
As wonderful as the E500 is to drive, XM makes it even more pleasant an experience.
see the sirius.com website for pricing options, they have a lifetime (for them, it might not be too long) subscription for $399 now.
That's why you will see the two camps, but you are absolutely right, Sirius won't make it. It is run quite differently than XM. The 'ex' used to work at XM, so I know all about it.
Sirius has money in the bank and is not in debt.
XM, is seriously in debt, has two satillites that are falling apart in space. Thier insurance copy will not cover the sats so they will have to replace them putting them further in debt.
While XM currently has more subscribers it had a 9 month head start and is only 50% ahead. Given the market is something like 2 billion possible, I doubt you can call the game with only a total of 1.6 million subscribers between the two.
Sirius has 60 completely commercial free music streams, XM has 30 that include comercials...
When the Sirius unit is installed with the Command system it will work on screen allowing you to select by genre, and also allows you 10 presets. The stream name will show on the instrument cluster display as well.
MB takes a lot of time to select the parts all the way down to the right type of botls and nuts, why would you think that they would stop here??
XM and Sirius are both much better than radio, if you want no commercials during your music and complete integration with you vehicle, get Sirius.
